Engine Coolant warning light
Moderators:Popsjag, J44EAG
snaefell
Postby snaefell » Wed Oct 06, 2021 10:32 am
Having replaced my 3.5V8's expansion tank I am still getting the red light on the dash & low engine coolant message,any ideas for clearing this please guys.,
andypryce
Re: Engine Coolant warning light
Postby andypryce » Wed Oct 06, 2021 7:08 pm
Faulty sensor perhaps?
XF Sportbrake 2020 / XK8 1998
cybercontroller
Postby cybercontroller » Wed Oct 13, 2021 12:23 pm
Have you visually checked if the coolant level is low? There could be another leak somewhere.
Jaguar XJ8 4.2 MY2004
snaefell
Postby snaefell » Thu Oct 14, 2021 7:47 pm
It had crossed my mind & when I first checked the level did need topping up but since then it has been fine,,I have been told by a number of people that it needs a device plugged into the data point to clear it,hopefully I will get that sorted next week,cheers guys.
andypryce
Postby andypryce » Thu Oct 14, 2021 11:26 pm
Interesting, the system should reset itself I would have thought once the level is ok, see what happens after it is cleared. If persists I would definitely suspect the sensor.
snaefell
Postby snaefell » Wed Oct 27, 2021 9:27 pm
Finally got the car back to the garage yesterday & the light was reset via the data port so no more red light,happy days,got so used to checking the temperature gauge every five minutes though I'm finding it a hard habit to break!
Thanks for your replies guys
andypryce
Postby andypryce » Thu Oct 28, 2021 9:28 am
Good result, may be worth buying a cheap code reader that you could use to reset fault codes, after noting them down obviously!
Many available, just enter code reader into amazon.
Postby ptjs1 » Thu Oct 28, 2021 10:14 am
Glad it got sorted!
For a number of years, I've always carried in my car a simple OBDII bluetooth plugin and I have the Torque Pro App on my phone. Total cost of those two is £10. I use them every single week to do favours for neighbours and friends, reading engine error codes, resetting EML etc. The App also has the ability to read most of the digital data fed back to the ecu such as lambda readings, oil pressure, engine temp readings, AFR reading etc etc.
So absolutely cheap as chips and invaluable. Every owner of a post-94 car should have something like this and clearly cost is not a restriction.
snaefell
Postby snaefell » Fri Oct 29, 2021 2:23 pm
Cheers guys,but after 20+ years in a car plant,the last 10 using hand sets to check a couple of hundred cars' electrical systems a day(or night!) I would be pleased never to plug one in every again!
andypryce
Postby andypryce » Sun Oct 31, 2021 9:49 am
:D
