Windscreen wiper motor refit
Moderators:iRS, Art1012
JohnSampson2012
Postby JohnSampson2012 » Sat Dec 14, 2019 12:03 pm
Has anyone refitted a windscreen wiper motor, how did you get the link from the motor to the central wiper crank to fit without fouling any of the stuff behind the bulkhead?
richard.whittington
Re: Windscreen wiper motor refit
Postby richard.whittington » Sat Dec 21, 2019 10:45 am
Hello John
What Model and year is your car.?
I have refurbished the wiper mechanism on my E Type series three, amazingly without difficulty, and it actually works.
Fortunately, access was good, insomuch as I had removed the Fascia beforehand.
I photographed the installation as I proceeded, and can send them to you if you think they may be of assistance.
K Regards
R Whittington
richard.whittington
Postby richard.whittington » Sat Dec 21, 2019 10:55 am
Hello John, again,
It just occurred to me that, when working on my car, for guidance, I use the following :-
1/ Repair operation manual by Jaguar
2/ SNG Barrett parts and accessories catalogue.
Looking at both the above helps you to understand the installation and removal or refit
K Regards
R W
JohnSampson2012
Postby JohnSampson2012 » Thu Dec 26, 2019 7:10 pm
Thanks Richard,
I have stripped down the motor and subsequently decided to get it refurbished. I have obtained a circuit diagram and have been able to bench test the motor to prove it out before fitting in the car. This is worth doing to ensure that all is working before final fit
The key is to ensure that the blade linkages are free moving prior to fitting the motor to ensure that the motor does not stall.
JohnSampson2012
Postby JohnSampson2012 » Mon Jan 06, 2020 4:11 pm
I have obtained a circuit diagram for the operation of the windscreen wiper motor which can be used for bench testing the motor without needing to take the switch out of the car.
Connect the brown and white leads together, connect the green to a positive battery terminal.
Slow running: connect the blue, yellow and black leads together and connect to the negative terminal of the battery, the red lead is not used
Wiper motor diagrams
Fast running: connect the blue, red and black leads together and connect them to the negative terminal of a battery, the yellow lead is not used
