Clear Lenses
Simont485
Clear Lenses
Postby Simont485 » Mon Jul 08, 2019 7:32 pm
Just been reading a piece in JWM Magazine about a XJS Superchrged 4.0...….
One of the things that caught my eye was the clear indicator lenses fitted to the front and side....any ideas where these may have come from?
The XJS in question was a Celebration model.
Simon
1994 Jaguar XJ12 6.0litre
1996 Jaguar XJS V12 6.0litre
Simont485
Re: Clear Lenses
Postby Simont485 » Fri Jul 12, 2019 8:33 am
Also are the front indicators the same on the 'big bumper' models and the 'rubber bumper' models?
Simon
Simont485
Re: Clear Lenses
Postby Simont485 » Fri Jul 26, 2019 6:12 pm
So I thought Id give it a go and see what it looks like...….
Front
Side repeaters
Your thoughts...….
Simon
davidr
Re: Clear Lenses
Postby davidr » Fri Jul 26, 2019 9:25 pm
I'm a fan of originality but they don't look out of place.
I would like to know more about its SD1 stablemate!
Simont485
Re: Clear Lenses
Postby Simont485 » Sat Jul 27, 2019 1:49 pm
It's a Vitesse TP.....1986.
Simon
Re: Clear Lenses
Postby ptjs1 » Sat Jul 27, 2019 5:16 pm
Simon,
A TP - very nice!! I loved the 2 SD1s that I had in the 80s. Great cars!
So, are your clear lenses just some photoshopping or did you actually find some? If so, where? I quite like the idea of those on my 4 litre.
davidr
Re: Clear Lenses
Postby davidr » Sat Jul 27, 2019 9:53 pm
Twin Plenum Vitesse! Very nice! Quite rare nowadays I'd have thought?
Like Paul, I had 3 SD1's in the 80's and loved them all
Simont485
Re: Clear Lenses
Postby Simont485 » Tue Jul 30, 2019 6:53 am
Simon
PM sent.
Simon
Simont485
Re: Clear Lenses
Postby Simont485 » Sun Aug 18, 2019 10:45 am
So having fitted the clear lenses the side reflectors then stood out.....so have 'hidden' them a little.....
Still undecided if its ok or not....but it can all be put back to original easily!
Simon
Re: Clear Lenses
Postby ptjs1 » Sun Aug 18, 2019 12:26 pm
Simon,
I quite like the look! I'm nearly ready to start my own upgrade experiment.
What bulbs did you use in the side indicators? I purchased some 25 SMD amber LEDs but because they sit quite close to the inside of the lens, I think they'll spoil the clear look.
So I've bought some different ones also advertised as "Amber", but I think they'll be too yellow / white, when I power them up?
Also, what did you use to darken the side reflectors? I still have my daughter's old paint box to hand!
Simont485
Re: Clear Lenses
Postby Simont485 » Sun Aug 18, 2019 3:35 pm
The bulbs I used are Osram silver coated amber bulbs on Amazon.....chrome indicator sidelight bulbs......
As for the reflector, I used some sticky window tint 35%.(ebay) Cut a template and then stick to the lens...….its a bit fiddly but can be removed if you want to go back to standard!
Simon
Re: Clear Lenses
Postby ptjs1 » Fri Aug 30, 2019 6:39 pm
So, part one is completed. Clear side lenses and some amber 501 LED bulbs that appear completely clear when not in use, but flash amber brightly.
Part 2, the front indicators is also in train but is causing a few issues....
ng4xjs
Re: Clear Lenses
Postby ng4xjs » Thu Jun 11, 2020 2:58 pm
My problem is the rear indicator lenses (XJS) . Just not bright enough. Think I'll take off give a good internal clean and replace bulbs. Someone hooted me the other day. Bright sunlight so guess they were not able to observe that I had indicated my intentions.
Happy Days
Nick
1994 4.0 XJS AJ16 BRG
2009 2.2 X Type Diesel BRG
2007 4.2 X150 Silver
