expansion tank
Graham
Re: expansion tank
Postby Graham » Tue Apr 10, 2018 8:37 am
Just had a thought is it possible to fit a face-lift expansion tank?
Desperation setting in :D
Graham
2005 Jaguar S Type 4.2 V8 Petrol AUTO
Montana5
Re: expansion tank
Postby Montana5 » Tue Apr 10, 2018 9:25 am
I take it yours is pre first facelift - 2002.5 M45254 though that identifyer means diddly squat, in reality and used by Jaguar service documentation, first facelift is early 2002 and M44998 on. The only models to use a slightly different Tank are the 2.7 Diesel and 4.2 SC.
Is yours the same as this...
https://www.ebay.co.uk/itm/JAGUAR-S-TYP ... 0778332110
Doug.
S Type Forum Moderator
Graham
Re: expansion tank
Postby Graham » Tue Apr 10, 2018 9:49 am
Mine is earlier,M31525,built Aug 2001 registered 29/01/2002.
https://www.britishparts.co.uk/jaguar-p ... tank-p7251
Graham
Graham
Re: expansion tank
Postby Graham » Tue Apr 10, 2018 11:46 am
Contacted Berkshire Jaguar,he has a long waiting list for these so it does not look promising at all.
I have located secondhand ones but not convinced to purchase.
I will put my renovation plans on hold for now.
Graham
Graham
Re: expansion tank
Postby Graham » Sat Apr 14, 2018 7:07 am
Just a small update really.
Sourced a secondhand expansion tank,which arrived yesterday.
Not an ideal option i know but with no new ones available and nobody knowing when they will become available,i thought i would
have a backup.
Going into the indy on Tuesday initially for a suspension overhaul but will now have the cooling system tested.
Graham
jeff1954
Re: expansion tank
Postby jeff1954 » Sun Apr 15, 2018 5:15 pm
Have a look through the Mag for parts ie David Manners / SNG Barrat/ Euro Jag You will be able to get most things, sometimes brand new.
I'm also replacing spring clips for Jubilee clips as I renew parts
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Graham
Re: expansion tank
Postby Graham » Mon Apr 16, 2018 8:41 am
Thanks for replying Jeff.
Already tried them,i have now a secondhand expansion tank which will be fitted this week.
Graham
Graham
Re: expansion tank
Postby Graham » Tue Apr 17, 2018 2:47 pm
Just an update.
I had the replacement secondhand expansion tank fitted today,all working fine now.
The original was found to have a large vertical crack not visible without taking it out.
Fingers crossed that it will last until new ones are available.
Thanks to everyone for their contribution.
Graham
jeff1954
Re: expansion tank
Postby jeff1954 » Sun Apr 22, 2018 4:21 pm
Glad you got it sorted Graham.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Re: expansion tank
Postby J44EAG » Wed Apr 25, 2018 8:56 am
Jaguar are not really supporting elderly cars once they get to around fifteen or sixteen years old. This is somewhat frustrating for many of us.
I looked into trying to obtain a new wiper mechanism for my X350 recently. These are also no longer available. (NLA). Rob and Mike H regularly meet with Jaguar to discuss badly needed parts supply with them in the hope that some of these impossible to obtain parts can be brought back into production. Sometimes they are successful, on others the situation still remains critical. Even direct approaches to the out-source manufacturers frequently draws a blank.
If you are really having difficulties, give Rob or Mike H a call and discuss further.
Graham
Re: expansion tank
Postby Graham » Wed Apr 25, 2018 9:16 am
Thanks for the heads up Mike.
Graham
Graham
Re: expansion tank
Postby Graham » Thu May 24, 2018 7:12 pm
Please to see that from the latest club magazine that early expansion tanks are to be manufactured again. :D
Cliveheathorn830
Re: expansion tank
Postby Cliveheathorn830 » Tue Jul 02, 2019 7:57 am
Good morning all, I have recently bought a 1999S-Type, I need the expansion tank, part No XR816503.
I have tried SNG & the other usual places with no luck
Can anyone help, as I have a beautiful car that I can’t drive
Here’s hoping
Clive
Graham
Re: expansion tank
Postby Graham » Tue Jul 02, 2019 12:24 pm
Hi Clive,
i could only source a secondhand one via typing into Google the required details.Lots of online parts suppliers and i registered with one of them.
They send details to lots of Jaguar breakers who then will contact you with thier offerings.
Good Luck.
Graham
Montana5
Re: expansion tank
Postby Montana5 » Tue Jul 02, 2019 3:31 pm
As you may have read recently in the JEC Magazine the JEC were working with JLR Classic Parts to have the Expansion Tanks produced, the last I heard was that they were now available (Jan 19), you can check with them and or contact them for an update.
https://www.jaguarclassicparts.com/u...expansion-tank.
I also heard that 99-2002 part no XR816503 had been superceded by part no XR849532, you could try a search for that
Doug.
