pre facelift headlight mountings
keri
Postby keri » Mon Jan 28, 2019 11:42 pm
Hello to you all can anybody help me with the headlight mounting brackets as you know there are 3 per lamp 2 sides and 1 lower now it appears the lower one is different from the sides the part numbers are different but how do you tell which is which when looking at the mount.
thanks
davidr
Re: pre facelift headlight mountings
Postby davidr » Mon Jan 28, 2019 11:58 pm
Hi Keri - yes there are 2 different part numbers quoted but I have to admit that I struggle to tell them apart. I can only recall what felt like ages of battling and swearing to get the bloody things to engage properly without pushing the adjusters through. They are a nightmare. If its any consolation (which it isn't!!) the facelift ones are much easier!
cabriolet
Postby cabriolet » Fri Mar 15, 2019 8:27 pm
After months of searching I recently was able to purchase some really good examples of these headlight adjusters. The only difference I can see between the 2 types is the shape of tension spring, so if anyone wants to see mine I will try and download photos.
cabriolet
Postby cabriolet » Tue Mar 19, 2019 9:13 am
From this photo you can see the difference between the 2 headlight adjusters. You will see one component is black and one is white but I think this maybe early and late versions of material used. The other obvious difference is the. Shape of the spring. The one with the black component is the single adjuster that is fitted below the headlight the white one is one of two that fits either side of the headlight. I hope this description is clear
cabriolet
Postby cabriolet » Thu Mar 21, 2019 12:03 pm
As the only difference is the spring, I decided to try and swap it to the other adjuster. This was an easy process so no need to by the correct type but just use the spring off your old unit (only feasible if you have an old one). It looks obvious that the main reason people replace these are not for damaged springs as they are quite robust.
Alan
