Seatbelts not retracting
Moderators:Popsjag, J44EAG
cornershop
Postby cornershop » Wed Feb 06, 2019 7:50 pm
Both front seatbelts and one of the rears are very slow to retract?
They have all been pulled out and slowly released, and don't appear tangled - has anyone found a cure?
Popsjag
Re: Seatbelts not retracting
Postby Popsjag » Tue Feb 12, 2019 8:53 pm
Try spraying them with furniture polish (pull the belts out to their full extent, spray lightly and let the belt fully retract slowly). It may take a few attempts of fully extended/retracted but it worked for me.
2003 X350 XJR - daily driver
Past vehicles:
cornershop
Postby cornershop » Thu Feb 14, 2019 8:32 pm
Interesting - what is thinking about using Furniture polish?
BrizzleJag
Postby BrizzleJag » Fri Feb 15, 2019 8:28 am
I would assume because they contain either silicone or wax, it will have a slight lubricating effect? Still if doesn't work at least car will smell clean. :D
PPV
Postby PPV » Fri Feb 15, 2019 11:47 am
I have used furniture polish for similar reasons on a variety of things that slide like vacuum cleaner wire retract systems, sliding curtain rails etc. Primarily it is the silicon in them but the wax also ensures it stays on longer than just the effect you would get from silicon spray alone. Well worth a try.
Paul V
Mk2 3.8
Nissan Micra K13
Porsche Macan S
cornershop
Postby cornershop » Sat Feb 16, 2019 11:30 pm
Thanks - I will certainly give it a try
Something like this? https://www.amazon.co.uk/Pledge-Multi-S ... B00BFDLCOE
Popsjag
Postby Popsjag » Mon Feb 18, 2019 8:24 pm
That should do nicely!
Past vehicles:
