3.6 downpipe
poprivet
3.6 downpipe
Postby poprivet » Fri Nov 09, 2018 2:26 pm
Having removed most of the exhaust system to gain access to the propshaft has given me the opportunity to inspect the exhaust system closely.
All four boxes are dated 1988 so are original and despite looking rusty are still perfectly solid. The downpipes from the manifold to the large single pipe are a twinwall construction and a lot of the outer skin has corroded away, although not leaking they really need replacing. Not available new of course and salvaged ones I have seen seen just as bad as the ones I have.
I thought I was being clever in buying one at the spares day ffom a 3.6 XJ40 which looked the same but turned out to be different. (Interestingly the XJ 40 one has a bracket where the only things supporting the XJS system are the manifold and the ones right at the end of the back boxes).
Most replacement exhausts don't include the downpipes, so I might have to look at getting one custom made.
Additionally, doing some research suggests that removing the centre boxes whilst giving a better sound and high speed power, reduces lower speed torque and increases fuel consumption so I would like to keep it fairly standard.
I'm putting the existing system back on for now but will update in the future if I find a solution.
Orkney
Re: 3.6 downpipe
Postby Orkney » Sat Nov 10, 2018 11:52 am
Hi, poprivet,
If you can hang on a day or two, I have one up in the gods of my workshop. Certainly not new but from memory it was very good. It came with a load of XJS spares I bought years ago. I will dig it out and take photos.
Ian
1989 XJ-S V12 Convertible
Previous:
1984 4.2 Series 3
1984 V12 Series 3 Sovereign
1988 V12 Series 3 Sovereign
poprivet
Re: 3.6 downpipe
Postby poprivet » Sat Nov 10, 2018 1:23 pm
Thanks, much appreciated.
Orkney
Re: 3.6 downpipe
Postby Orkney » Sat Nov 10, 2018 6:44 pm
Found it!
It looks very useable but if they are now made from unobtainium it might be worth having it coated in some way (ceramic, hot zinc?) to preserve it. I’ll pm you tomorrow or Monday with pics of the whole thing and some detailed close ups. If I needed one I would certainly be happy to use it.
Ian
Previous:
1984 4.2 Series 3
Phil 18
Re: 3.6 downpipe
Postby Phil 18 » Sat Nov 10, 2018 7:57 pm
I also have a perfectly good second hand one, with brand new rings. Bought as a spare at the time for my XJS.
Let me know if the one that you are possible buying does not work out
Phil
Phil
4.2 XK8 2004
Orkney
Re: 3.6 downpipe
Postby Orkney » Mon Nov 12, 2018 5:06 pm
I’ve sent a pm to you poprivet regarding the downpipes,
Ian
Previous:
1984 4.2 Series 3
Orkney
Re: 3.6 downpipe
Postby Orkney » Sun Nov 18, 2018 5:59 pm
Did you get fixed up with downpipes, I emailed pics to you but no reply,
Ian
Previous:
1984 4.2 Series 3
poprivet
Re: 3.6 downpipe
Postby poprivet » Sun Nov 18, 2018 6:43 pm
Hi Ian, I sent a reply the next day but maybe I got the address wrong. I've sent another email just now.
poprivet
Re: 3.6 downpipe
Postby poprivet » Wed Nov 28, 2018 4:34 pm
Many thanks to Orkney, a parcel turned up today with the replacement and aso thanks to Phil for the offer.
:D
Orkney
Re: 3.6 downpipe
Postby Orkney » Wed Nov 28, 2018 11:51 pm
Thanks for the update,
Glad you got the parcel ok,
Ian
Previous:
1984 4.2 Series 3
Phil 18
Re: 3.6 downpipe
Postby Phil 18 » Thu Nov 29, 2018 8:48 pm
Glad that you go sorted :)
Phil
4.2 XK8 2004
Phil 18
Re: 3.6 downpipe
Postby Phil 18 » Thu Nov 29, 2018 8:54 pm
ooops spelling mistake, i should have read it back, it should have read Glad that you got sorted lol
Phil
4.2 XK8 2004
