I have to change the air con drive belt and pulley on my 1997 3.2 Sport. The OEM pulley is very expensive in the UK so I would like to use a substitute. I read in an old thread that someone had used a Honda pulley (part number 0388-YD2), but I don't know the model of Jaguar he fitted it to.
Will this fit my car and if not, are there other pulleys I can use? I know about the Gates 38006; hard to find in the UK and also expensive.
Thanks in advance.
Air con idler pulley substitute?
Re: Air con idler pulley substitute?
+ Idler pulley
EAC9514
↳ NBC5012AA £40.23
I have a used one here, if you want too. PM for details.
EAC9514
↳ NBC5012AA £40.23
91 4.0 XJ6 Manual
92 4.0 XJR Manual
93 3.2S-4.0S Man conv
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
96 X300 Daimler Six LWB
97 X300 Sport 4.0 Manual
00 LR Discovery 2 TD5 ES A
03 X350 4.2 XJR
92 4.0 XJR Manual
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
03 X350 4.2 XJR
Thank you for the information naki and for the offer of a pulley, much appreciated. I had just bought a Febest 0388-YD2 though; I'm waiting for a dry day to fit it.
Various sources say that the pulley adjuster should be turned clockwise to loosen the belt. Is this clockwise from underneath the car, or clockwise from above?
