Hi there.
I recently observed that one of the "D"-shaped bushes for the anti roll bar is bad on my car: Not good
Are these things difficult to change?
Car in question is a 1994 DD6
Thanks in advance
Anti roll bar bush.
Björn V
XJS 6.0 V12 -94
Morgan +8 -98
XJS 6.0 V12 -94
Morgan +8 -98
Re: Anti roll bar bush.
Hopefully this diagram will give you an insight of what's involved. Remember the usual health & safety issues when your vehicle is up in the air.
http://www.jaguarclassicparts.com/illus ... sh5074.jpg
I assume it is item number 3 (2 off) that you wish to replace?
It will be easier to unbolt both brackets at the same time, replace the rubbers and then retighten the brackets back up.
Steve.
Steve.
2003 X350 XJR - daily driver
Past vehicles:
Past vehicles:
Thank you for the picture. Yes, it is the number 3 item I want to replace.
I will change both of them items.
Doesn't seem too difficult to get to, once you can get under the car safely.
Björn
Björn
Björn V
XJS 6.0 V12 -94
Morgan +8 -98
XJS 6.0 V12 -94
Morgan +8 -98
two 13mm bolts, and its away. possibly the easiest bush to change on a jag.
also note the parts numbers different even between XJ12 and DD6 variants.
due to slight thicker ARB on the XJ12.
91 4.0 XJ6 Manual
92 4.0 XJR Manual
93 3.2S-4.0S Man conv
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
96 X300 Daimler Six LWB
97 X300 Sport 4.0 Manual
00 LR Discovery 2 TD5 ES A
03 X350 4.2 XJR
92 4.0 XJR Manual
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
03 X350 4.2 XJR
Thanks for the tip, Naki.
There seems to exist several types for this bush. I hope I can get the right one.
Will report back when I have actually done the change.
Björn
Björn
Björn V
XJS 6.0 V12 -94
Morgan +8 -98
XJS 6.0 V12 -94
Morgan +8 -98
Bjorn,
As far as I know, the DD6 has a non-sportspack setup. If I'm right, you can just buy the bushes still from Jaguar - part number CCC2806 see here:
http://www.jaguarclassicparts.com/uk/ja ... ulcrum-tie
Hope that helps
Hope that helps
That´s how I understand it too. DD6 does not have the sportpack. At least not normally.Bjorn,
Hope that helps
Björn V
XJS 6.0 V12 -94
Morgan +8 -98
XJS 6.0 V12 -94
Morgan +8 -98
sportpack was an option on all XJ40/ 81 from 1990 onwards, but it is unlikely to be found on a Daimler.
91 4.0 XJ6 Manual
92 4.0 XJR Manual
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
03 X350 4.2 XJR
92 4.0 XJR Manual
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
03 X350 4.2 XJR
