Postby jeff1954 » Fri Dec 26, 2014 5:11 pm
Hi thomas45
It could be one of the downpie flexis as in agriff's case, but check to see if your Fuel Fired Heater is opperating if it's below 5 deg's C when you are getting the fumes in the cabin.
If the FFH is opperating and creating the fumes you can select recirculation on the Climate Controll and this will keep the fumes out of the cabin. I will say this, that if it is your FFH that is creating the fumes you are a lucky man as thease heaters are very tempremental and don't allways work.
PS Iv,e had my car for 6 years now and the dam thing has only worked twice even after trying variouse re-sets and re-start procedures. When the heater is working the water temp will be up after about a mile or so if not it will take about 6to7 miles before you get nice warm air into the cabin.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
