This may be of use to someone, compares wheel sizes.
It would be handy if someone knows which XK8 wheels fit XJS cars. I know some members have successfully fitted them but I guess they are not all compatible?
http://www.wheelfitment.net/jaguar
Wheel fitment, offset, PCD etc.
Re: Wheel fitment, offset, PCD etc.
all XK8 wheels should fit up to the days that the Ford fitment was adopted
the rear wheels which are wider and have a bigger offset will bolt straight on , , might have to double check for the facelift XJS due to outboard brake calipers though , but pre-fecelift are fine.
the fronts need a 20mm hubcentric spacer to be bolted to the hub , and then the wheels bolted to the adaptor plate to ensure a good fit,
i have fitted 18" Flute XK8 alloys to my own XJS and there are no issues at all , except for maybe a firmer ride due to the extreem low profile tyres
Thanks BB, that's useful to know.
NP
3650 by MyPix on Talk Photography
just to illustrate the offsets for the 18" Flute alloys from an XK8
