Hello,
While driving back from Germany , the engine stalled when slowing down from 150kph to 50 kph - have to slow down when crossing border into Holland. The same happened when crossing into France from Belgium. Car restarted immediately with some white smoke. A bit concerning as both times we were in the outside lane. The rest of the journey back to Durham was fine. Any ideas as I am thinking about bringing the car back to Germany when the weather improves and I don't have to use winter tyres (they are brilliant) - I spend a lot of time in Germany.
best wishes
Geof
Engine stalled on motorway
Re: Engine stalled on motorway
Hi Geof ,
Your model year of XK100 should have been subject to a recall and the fitting of an improved throttle body as earlier version suffered the same symptoms you are having , this was done by Jaguar free of charge but they no longer honour the arrangement , was yours fitted with the upgraded throttle body
Hope this helps
Nik
PS Mine was upgraded free of charge about five years ago
Hope this helps
Nik
Hello Nik,
My xk8 is 1997 but I have little history - main owner in the past died and books lost. I did research things and spoke to the garage he used but no real detail. Consequently I had the tensioners etc updated to latest type, new water pump and thermostat housing replaced when I bought it. Is there any way I can find out if the car had the throttle body updated ? If not is it worth sourcing a replacement.
Quite an alarming experience when the engine stalled and I had to try to get to the hard shoulder - my partner refusing to drive the car now !
Best wishes
Geof
Best wishes
Geof
Geof
1997 XK8
1997 XK8
Hi Geof,
For your 97MY I believe the throttle body cap was chrome , later fitments are black plastic ,
Hope this helps ,
Nik
Hope this helps ,
Nik
Hello Nik,
Thanks for the information. Unfortunately I am back in Germany so I can't check at the moment. Maybe I can get my friend, who does any work on my car to check.
Geof
Geof
Geof
1997 XK8
1997 XK8
I had exactly the same problem with my 97 XK8.
Mine would stall on the motorway when ticking along which is pretty hairy!.
I bought a second hand throttle body from Jag Spares Northeast and my local mechanic fitted it and problem sorted!.
Total cost for the part and labour was about £200.
Best of luck with getting yours fixed!.
Best regards
Dave
Best regards
Dave
