Heated rear screen not working?
Moderators:robv12, DavidEm
blackflash
Postby blackflash » Mon Dec 07, 2009 10:58 pm
On a misty day last week, my rear view mirrors cleared nicely but my rear screen appeared to do nothing. I have not been able to recreate the experiment due to weather conditions...
I have located and checked the fuse and it looks fine. I await a misty or frosty day when I can check this out properly but, if it does nothing, what should I check next?
I had my heated front screen replaced recently - am I right to assume the rear scren circuit is completely separate so nothing could have been upset in the process?
Thanks,
Nigel
Blackflash
'05 S-Type R in Liquid Silver with Dove leather and Aluminium trim
u102768
Re: Heated rear screen not working?
Postby u102768 » Tue Dec 08, 2009 10:07 am
Thanks,
Nigel
Other than they are all controlled by the Air Conditioning Control Module, they do not seem to share the same circuit.
Have you checked the relay, relay No. 2 in the boot/trunk fusebox? It should be brown.
Richard
blackflash
Postby blackflash » Tue Dec 08, 2009 11:51 pm
How do I check a relay once I have located it? What am I looking for?
Sorry for naive question!
Blackflash
blackflash
Bump!
Postby blackflash » Sun Dec 13, 2009 10:32 pm
Chaps,
I used to see "bump" messages on another owners bulletin board a few years ago and eventually realised it was just a way of nudging your message up the rankings if you hadn't received a reply...
If anyone can help me with my request re what to look for when checking a relay then I'd appreciate it.
Many thanks,
Blackflash/Nigel
Blackflash
u102768
Postby u102768 » Mon Dec 14, 2009 10:01 am
I am not an electrician but a quick search on Google finds this:
http://www.ehow.com/how_4596906_test-car-relay.html
There are no doubt others too.
I guess the fastest way to test the relay would be to look for another known good one elsewhere on the car of the same type/colour and substitute it.
blackflash
Postby blackflash » Mon Dec 14, 2009 9:07 pm
Thanks. Not entirely sure I'd trust an article which gets an average review of 1.5 stars out of 5... But it makes clear I need equipment which I don't have and by the time I've bought it probably for one use only I would probbly be better off paying a garage to do it for me.
Which is useful to know!
All the best,
Nigel
Blackflash
u102768
Postby u102768 » Tue Dec 15, 2009 10:33 am
Halfords sell a circuit tester for 3.29GBP!
I don't know if you are a member but, if not, I can highly recommend joining the X300 forum at http://forums.jag-lovers.org/.
There are hundreds of members some of whom are Jaguar mechanics, auto electricians etc so you are likely to get more timely, expert help there.
blackflash
Bargain!
Postby blackflash » Tue Dec 15, 2009 11:02 am
£3.29 sounds like it's worth a punt!
I couldn't possibly join the X300 forum, that would be like having a clandestine affair...
All the best,
Nigel
Blackflash
joejag308
other sites
Postby joejag308 » Tue Dec 15, 2009 1:18 pm
u102768
Without seeming too harsh .......go forth and multiply.......!!....Joe :lol:
