On a misty day last week, my rear view mirrors cleared nicely but my rear screen appeared to do nothing. I have not been able to recreate the experiment due to weather conditions...
I have located and checked the fuse and it looks fine. I await a misty or frosty day when I can check this out properly but, if it does nothing, what should I check next?
I had my heated front screen replaced recently - am I right to assume the rear scren circuit is completely separate so nothing could have been upset in the process?
Thanks,
Nigel
Heated rear screen not working?
blackflash
Blackflash
'05 S-Type R in Liquid Silver with Dove leather and Aluminium trim
Re: Heated rear screen not working?
Thanks,
Nigel
Other than they are all controlled by the Air Conditioning Control Module, they do not seem to share the same circuit.
Have you checked the relay, relay No. 2 in the boot/trunk fusebox? It should be brown.
Richard
blackflash
blackflash
Bump!
Chaps,
I used to see "bump" messages on another owners bulletin board a few years ago and eventually realised it was just a way of nudging your message up the rankings if you hadn't received a reply...
If anyone can help me with my request re what to look for when checking a relay then I'd appreciate it.
Many thanks,
Blackflash/Nigel
Many thanks,
Blackflash/Nigel
Blackflash
I am not an electrician but a quick search on Google finds this:
http://www.ehow.com/how_4596906_test-car-relay.html
There are no doubt others too.
I guess the fastest way to test the relay would be to look for another known good one elsewhere on the car of the same type/colour and substitute it.
blackflash
Thanks. Not entirely sure I'd trust an article which gets an average review of 1.5 stars out of 5... But it makes clear I need equipment which I don't have and by the time I've bought it probably for one use only I would probbly be better off paying a garage to do it for me.
Which is useful to know!
All the best,
Nigel
All the best,
Nigel
Blackflash
Halfords sell a circuit tester for 3.29GBP!
I don't know if you are a member but, if not, I can highly recommend joining the X300 forum at http://forums.jag-lovers.org/.
There are hundreds of members some of whom are Jaguar mechanics, auto electricians etc so you are likely to get more timely, expert help there.
blackflash
Bargain!
£3.29 sounds like it's worth a punt!
I couldn't possibly join the X300 forum, that would be like having a clandestine affair...
All the best,
Nigel
All the best,
Nigel
Blackflash
other sites
u102768
Without seeming too harsh .......go forth and multiply.......!!....Joe
