96 xk8 auto box
deltasierra
96 xk8 auto box
Postby deltasierra » Thu Apr 15, 2010 8:34 pm
Today there was a long delay(3-5 secs) between selecting drive and drive being taken up. Transmission was hot/warm after a 50 mile drive and behaved normally shifting gear, box has done 80k miles, any ideas.
Dave
Nik
Postby Nik » Thu Apr 15, 2010 9:18 pm
Hi Dave ,
Could be a sign that although the gearbox is "sealed for life" it could do with a fluid and filter change , just make sure whoever does it uses the correct fluid :wink: ,
Hope this helps ,
Nik
Postby mike020150 » Mon Apr 19, 2010 2:31 pm
A delay on the take-up of drive can be caused by a low fluid level. Hence, a quick check under the car for leaks would be advisable to avoid being stranded with an overheated or damaged gearbox. Mike
deltasierra
Postby deltasierra » Sun May 02, 2010 8:39 am
Fluid level OK, looking at the XJ forum the neutral switch is mentioned. Problems have been caused by the switch sticking intermittently which would cause the symptoms I am getting. I have not yet found the time to troubleshoot the logic of this but I am going down that avenue first.
Any other tips welcome
Dave
bt965
Postby bt965 » Mon May 03, 2010 11:03 am
Hi, Don,t want to be prophet of doom but I had the same fault on my previous XK at about the same mileage. The cause was the input shaft which totally failed in the end
Bob
