XK8 XKR Powerfold Mirrors Problem
cgclassics
Postby cgclassics » Thu Dec 18, 2008 4:25 pm
The powerfold mirrors on my XKR 2002 year have stopped working. Were fine a few days ago. When I flick the switch I can hear a relay click, hold for a few moments and then release, but nothing happens and no motor sound. The mirror adjusting mechanism all works fine as does the steering wheel adjustment.
I can't see a fuse indication for the powerfold function, so wondering if anyone else has has this problem and sorted it before.
Craig
Nik
Postby Nik » Thu Dec 18, 2008 8:24 pm
Hi Craig ,
The powerfold option on your XK is controlled through the door modules , could be that your battery is on it's way out and the door modules require reprogramming :?: , depending where you are in the country, Kevin at DesignXKR would possibly sort you out with his WDS as the fault is almost certain to have logged a fault code ,
Best of luck ,
Nik
cgclassics
Postby cgclassics » Fri Dec 19, 2008 10:55 am
Hi - seemed to have fixed it - I came to the same conclusion last night that the door control modules were a good place to start based on the JTIS wiring diagram.
Also this morning when I got in the car the drivers seat was dead and the heated seat on that side didn't work.
So more in vain hope than anything else I removed the fuses one by one on the drivers side fascia fuse box, firstly to check they hadn't blown and secondly in case that reset anything. Hey presto once I did that everything worked - seat adjustment, powerfold, heated seats etc. So I guess I reset the door and seat control modules somehow. Window memory was all OK anyhow and I also have a brand new battery in the car.
Anyhow hope this helps others
Rgds
Craig
