Windscreen Wipers - mind of their own
howardryan
Postby howardryan » Mon May 08, 2006 8:01 pm
Can anyone help. My wipers wipe 12 to 15 times then stop irrespecive of the control stick position. Switch them off then back on again and get another 12 to 15 wipes and so on..Iv'e looked in the workshop manual but that talks about the Body Processor and the use of a PDU, which I don't have.
any ideas welcome.
Howard
GrandTourer
Postby GrandTourer » Wed May 17, 2006 8:37 pm
Hi Howard, welcome to the forum :D
I have not come across your problem before but hope other members are able to help. Of course, you can always contact our Technical Advisor of the XK8/R forum, David Marks, who has a huge experience in matters XK8 and others.
Hope you get sorted soon.
Karl, XK8 MY2000 Pacific Blue
Nik
Postby Nik » Wed May 24, 2006 10:46 pm
Hi , I had exactly this problem , it turned out to be the wiper motor, very surprised at how inexpensive a new wiper motor was fitted by the jaguar centre Hull (a genuine jag motor is well under £90 )
best wishes Nik
JohnFrewer
Postby JohnFrewer » Fri Aug 25, 2006 8:39 am
I had the same problem and have replaced the microswitch in the motor. So far it seems to be working. The switch is 99p plus postage from farnellinone dot com XCF3 S1Z1 order code 777-1720.
Time will tell if the one I've put in is up to the job. I've posted details on replacing it in the X300 section of jaglovers.
John
Don68500
Postby Don68500 » Tue Nov 20, 2007 9:29 pm
Thanks for the help
I’ll get a second quote for the wiper motor, £90 is a lot better than £400.00 (that was Rybrook’s of Chester).
The micro switch option sounds even better, John mentioned he’s posted details about replacing the micro switch in the X300 section of jaglovers, where do I find X300 jaglovers?
Sorry I’m new to the forum
Don
:D
JohnFrewer
Postby JohnFrewer » Sat Nov 24, 2007 7:17 pm
jag-lovers.org
It's about 2 years now since I replaced the microswitch and no problems so far.
John
Don68500
Postby Don68500 » Mon Nov 26, 2007 10:55 pm
Thanks for the info John, I found your info on jag-lovers, I’ll give it a try and let you know how I get on, again thanks, Don
