MODIFIED REAR LIGHT CLUSTERS ON 96-2000 XK8
PARA4
Postby PARA4 » Sat Nov 19, 2005 9:27 pm
HAS ANY BODY BEEN ABLE TO PUT LATER LIGHTS INTO THE REAR OF THE EARLIER XK MODELS AS I HAVE HEARD THERE IS QUITE A BIT OF WORK INVOLVED,ANY INFO ON THIS MODIFICATION WOULD BE APPRECIATED!
Scottish-Exile
Postby Scottish-Exile » Sun Nov 20, 2005 10:07 am
A few guys in the XKEC have done this. They advise that it was simple enough other than the fact that the new cluster is slightly deeper, so you need to cut out the back plate and then fashion up a new cover to hide the cluster in the boot. OK if you're DIY minded but not everyone would be comfortable taking an angle grinder to their car !
SWF
Postby SWF » Sat Dec 10, 2005 1:43 am
I am about to attempt this in the next week or so on my 1999 Convertible.
gasman1003
Postby gasman1003 » Sat Dec 10, 2005 10:21 am
Racing Green cars carry out the conversion for £499, including VAT.
Had mine done, worth every penny
SWF
Postby SWF » Fri Dec 16, 2005 12:13 am
Was about to start this job today.Took the old unit out and measured up the new bracket when I saw how much needed to be cut out ! Got cold feet and arranged for a professional to do it next week.
