Bolt of lightning Light?
bigjim
Postby bigjim » Sat Dec 19, 2009 8:47 am
Can any body tell me what the red warning light with a lightning flash on it is for, mine is on all the time. On my old XJ40 I think it was a fuse failure light (well it lit up when a fuse blew!) I have checked all the fuses and cleaned all the connections in the fuse boxes, but the light still comes on. I also changed the small unit under the main fuse box (High voltage control unit I think, 2 inch long, three male spade connectors, silver in colour bolted directly below fusebox) I don't know if it is relevent but the volt meter raises to 13v very slowly on start up. Any help would be welcomed as I have cured all the other odd wiring faults (low coolant, bulb warning etc) and this one is bugging me good and proper!
SimonR
Postby SimonR » Sat Dec 19, 2009 2:23 pm
Hi there,
See this thread.
Ignore my ramblings about warning lights being in the wrong places - I think my instrument pack is just different to the illustration.
In the end it turned out that the diode pack on the alternator was at fault so I had the whole alternator serviced (just to do a belt and braces job, you understand!). It's fine now. I wasn't noticing any other symptoms i.e. the battery was still charging and the volt meter on the dash read at the normal level.
Hope that helps!
SimonR.
Current cars: [b]1989 XJ-S 3.6 Manual[/b] & [b]2003 XK8 4.2L
[/b]
Previously enjoyed cars: other 3.6 Manual XJ-Ss and Daimler 4.0L XJ40s
