Gas /Petrol tanks
davewhit
Gas /Petrol tanks
Postby davewhit » Tue Nov 17, 2009 11:30 am
I'm considering fitting a gas conversion but do not wish to compromise the spare wheel. Has anyone knowledge of the fuel tank being replaced by a small petrol tank and a large gas tank. I need to run for long distances between fill-ups and the doughnut tank replacing the spare wheel appears too small for my needs.
Any advice or info welcome
Mr.Ian
Gas /Petrol tanks
Postby Mr.Ian » Tue Nov 17, 2009 7:11 pm
Not sure what model XJS you have but I was reading about a conversion a while ago where the boot floor was modified to accomodate the gas tank so the owner could still have their spare wheel in the upright position as normal.
1978 XJ-S V12 Auto - Under Restoration
bigjim
Gas /Petrol tanks
Postby bigjim » Fri Dec 04, 2009 1:18 am
I have not seen it done on an XJS but I have worked on a discovery where the main tank had been removed and a cylinder tank for the gas put in place of it with a 4 gal small petrol tank put in along side. Small petrol tanks are a available from racing suppliers or could be made up by a good metal working shop. It is worth having a look at some of the gas kit suppliers as I don't think it would be too difficult to locate a tank around the same diameter of a XJS tank and about 2/3rds the length.
I would be interested to see how you get on as this is somthing that I am looking at doing.
PaulE
Gas /Petrol tanks
Postby PaulE » Fri Dec 04, 2009 11:09 am
Work it out very carefully before you spend anything. If LPG gets popular bloody Gordon will bang the tax up just as was done with diesel.
1994 Coupe AJ6 engine
