Reluctant Getaway
shed
Reluctant Getaway
Postby shed » Wed Aug 26, 2009 1:25 pm
Hello all,
Having solved my recent no-start problem (ECU), my wonderful XJS 4.0 has moved on to its next problem.
Pulling away in first gear when its been started from cold, it will on about 50% of occasions lose power and only just manage not to stall. This problem is worse and much more obvious the more power you apply.
The problem often seems to go away if, after a short trip, you restart the engine and drive off, after which it will display normal behaviour, or just persevere until the problem goes away.
Can anyone please suggest what I need to be investigating to get this sorted? Torque converter or vacuum pipes?
Thanks.
_____
Ed
1994 XJS 4.0Ltr
extratime1983
Reluctant Getaway
Postby extratime1983 » Tue Oct 27, 2009 4:56 pm
Anybody have any ideas :?:
I recently started having a similar, albeit intermittent problem
Mr.Ian
Reluctant Getaway
Postby Mr.Ian » Tue Oct 27, 2009 7:12 pm
Could it be air fuel mixture when cold? ie too weak or too rich? would certainly cause the car to struggle from set off and would be worse if you tried to give it more throttle. Is it ok when warm? even after a 30 mins or so rest , restarting the warm engine is it ok then?
Just a thought though
1978 XJ-S V12 Auto - Under Restoration
