Locked out key inside
bwood727681
Postby bwood727681 » Fri Mar 17, 2023 9:19 pm
Hi All Newbie to JEC here have an X300 Sovereign with only one key. That is in the car and it has locked itself. Any ideas, I would rather not break a window..... Bonnet and boot are open car is in the garage so can get to tools and battery.
andypryce
Re: Locked out key inside
Postby andypryce » Sat Mar 18, 2023 5:07 pm
AA or RAC might be able to get in?
XF Sportbrake 2020 / XK8 1998
JimMann
Postby JimMann » Sun Mar 19, 2023 10:56 am
You don't say where you are, but there may be an auto locksmith in your area. Alternatively, find a local / friendly car thief with the right tools! Do you have a fob or simple key?
Jim Mann
Jim Mann
Banchory
Doherto
Postby Doherto » Tue Mar 21, 2023 6:20 pm
Youtube suggested this
https://www.youtube.com/watch?v=FydPl7_vp6w
Don't know if it will work with your car but worth a try ?
SimonR
Postby SimonR » Tue Mar 28, 2023 7:44 pm
I did exactly this with my XJ40 and whilst I'm not sure how similar the door designs are, in case it helps, here's how I got in:
I got a wire coat hanger, opened it out and formed one end into a loop big enough to fit over the interior door release handle. Then I got a crowbar, and using some thick cardboard and masking tape to protect the car roofline and door top, gently levered the top of the door open enough to slip the looped end of the coat hanger into the car. The next bit is a bit fiddly - you have to bend the coat hanger so that as you feed it into the car, it bends around and enables you to hook it on the handle - this took me about half an hour to perfect. Once you've got it hooked, you can slide the other end round toward the back of the door so that you can pull it backwards to operate the handle and release the door.
Bonus points are awarded in the first instance for not locking yourself out of the car with the keys in the ignition and the engine running...
bwood727681
Postby bwood727681 » Mon Apr 17, 2023 3:34 pm
Managed to get in using a piece of parcel strapping found in a nearby skip. This slides through the door seals easier than a coat hook and you get better control of hooking it round the door pin. This was suggested on another forum. Have got a spare key now!
Andy P
Postby Andy P » Wed Apr 19, 2023 12:16 pm
Glad you eventually got back in.
You can never have too many spare keys :) .
Take care.
Andy :D
