Removal of engine cover
sportbrake
Postby sportbrake » Sun May 29, 2022 10:21 am
I notice that most engine covers on the F Type seem to stain easily which I find annoying. I would like to remove cover and spray it. I have not removed cover before. Is this a simple process? Sorry for such a simplistic question. Chris
Andy P
Re: Removal of engine cover
Postby Andy P » Sun May 29, 2022 11:31 am
Hi sportbrake,
Have not removed cover myself but from what I have read it just pulls off.
Try pulling at each corner with a little force and it should come away.
I have found these two threads about the engine cover which you might find interesting.
https://www.jaguarforums.com/forum/f-ty ... er-256346/
https://www.jaguarforums.com/forum/f-ty ... er-196304/
Good luck and take care.
Andy :D
Postby mike020150 » Mon May 30, 2022 8:47 am
The engine covers on the V6 and V8 engines do just pull off. Pull vertically to avoid damaging the fixings. Usually, they require a sharp tug to release the first fixing. Then, the others follow more easily. Mike.
sportbrake
Postby sportbrake » Wed Jun 01, 2022 9:48 am
Thank you both for your replies. Chris
