Hi All,
I found these 2 pieces in the boot of my recently-purchased XKR coupe
Can anybody help me identify them?
Thanks in anticipation.
Andrew
Can anybody identify these?
Re: Can anybody identify these?
They are the water shedding strips that fit on top of the headlamps. They take the water off the wing tops and channel it across the headlamps. I'd send you a picture of them on my own car but I'm at work!
andrew.graham97934
Ah OK thank you!
Yes if you have a pciture when convenient that would be great thank you.
Just wondering why they are in the boot!?
It will be a few days before I can send you pictures as I'm away for a while.
If you look at the lights you will see how they fit. They are effectively a continuation of the drain channel on the top of the wing.
I would imagine that they were in the boot because for whatever reason the lights have been removed from your car and whoever did it forget to put them back it couldn't remember what they were. Or may be the person who took them apart wasn't the same one who put it back together?
andrew.graham97934
Thank you David. Much appreciated.
I have already found little things like drainage tubes / channels not connected etc.
So-called experts eh?!
Rgeards
Andrew
Rgeards
Andrew
