S-type engine oil capacity
rick.potter1777
Postby rick.potter1777 » Wed Jul 21, 2021 4:53 pm
I’ve just changed the engine oil in my 3.4l S-type engine and refilled it with the quantity of oil prescribed in the service manual (6.75 litres). With that quantity the oil level doesn’t even register on the dipstick. Can any s-type owners out there please tell me how much oil they have used in their cars to get the appropriate level?
Regards to all
RickP
JimboV8
Re: S-type engine oil capacity
Postby JimboV8 » Wed Jul 21, 2021 5:10 pm
Perhaps you have the wrong dipstick fitted. Just a thought.
2012 XKR, Black pack, Aero pack, Speed pack 8) :mrgreen:
​Past:-87'XJS 3.6L, 93'XJ40 3.2L gold, 95'XJ6 4.0L sport, 00'XJ8 3.2L sport, 2005 XK8 4.2L, 2009 X150 5L Portfolio coupe, in that order and enjoyed all of 'em. :D
rick.potter1777
Postby rick.potter1777 » Thu Jul 22, 2021 8:25 am
Hi Jimbo,
Thank you for taking the time to reply.
I do indeed have the wrong dipstick but, having failed (so far) to track down the right one I’ve been making due allowance. David Reilly of the International S-type register was kind enough to supply the dimensions of the correct dipstick so I have used those to make up a temporary “measuring stick” for the purpose of determining the correct level.
Kind regards
RickP
B87UL
Postby B87UL » Thu Jul 22, 2021 10:07 am
RickP
To answer your question directly………. 12 Imperial pints or 6.75 Litres, including the filter.
In addition, I have checked the 12 imperial pint capacity against the dip stick calibration marks with the sump removed on my 3.4ltr S Type. The dip stick full mark agrees with a 12 pt refill, including filter.
Many years ago, as a fleet engineer, we ran a MkX 3.8 ltr between Derby and Milan at the rate of 80,000 miles per year just for a short time. In oil consumption terms and plug fouling I can tell you that there is advantage in only checking the oil level in an engine HOT condition and only refilling to the level between high and low on the stick.
You would be surprised at how many owners are running around with the car front end high, shot engine mountings and the gearbox rear mounting incorrectly set up, and wonder why the engine uses oil !!!!
Norman
rick.potter1777
Postby rick.potter1777 » Thu Jul 22, 2021 11:19 am
Thank you Norman; a perfect reply. Now I need to figure out what is wrong with my set up!
Kind regards
RickP
