Sump drain plug
TheColonel
Sump drain plug
Postby TheColonel » Sun May 09, 2021 7:36 pm
I have recently bought a 2001 3.0 V6 SE and am planning to do an oil change shortly. Does the drain plug have a copper crush washer and if so can anyone advise either the part number or inside diameter please?
Michael
rosemary
Re: Sump drain plug
Postby rosemary » Sun May 09, 2021 7:56 pm
Go to British Car Parts Jaguar, they have a variety of Sump Plugs and Washers, Alternatively AutoParts Jaguar or SNG Barratt, Just put in your Model and VIN.
Dave
Dave Hart
jeff1954
Re: Sump drain plug
Postby jeff1954 » Fri May 14, 2021 6:27 pm
My 2004 Diesel sump plug had an integral seal which Jaguar stated should be renewed every service at a cost of about £7.00 each. I did that for the first couple of services then used the old ones after that which didn't show any signs of a leak.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
TheColonel
Re: Sump drain plug
Postby TheColonel » Fri May 14, 2021 9:52 pm
Jeff
Jeff,
Thank you for this info.
Michael
