Side light
weddingjags
Side light
Postby weddingjags » Mon Jul 13, 2020 12:33 pm
Does anyone know the screw size for fitting the front side lights? As usual the after market lights I bought don't sit quite the same as the originals and the screw is just too short to bite so I need to find a new one of the same type.
piman
Re: Side light
Postby piman » Mon Jul 13, 2020 1:20 pm
Hello WJ,
you may just have to try some common ones as there is no saying that the reproduction uses the same thread? Didn't it come with the securing screw?
I would guess the original may be a 2 or 4 B.A. or one of the odd 4/32 UNF screws?
Good luck?
470HW
Re: Side light
Postby 470HW » Fri Jul 17, 2020 12:53 pm
I had a devil of a job finding these screws. In the end I ordered a range. I'm they're definitely UNF. UNF screws below 1/8" are listed in numbers e.g. #6 #8 #10. I'm pretty sure the ones you're after are 1/2" long, countersunk UNF #8 but I would order #10 too. As a note, they're often listed as threads per inch e.g. 24 TPI for UNC or 32 TPI for UNF. I believe thats correct. Hopefully someone will read and verify or correct. I'll check through my receipts and confirm when I get back home in a few days but hopefully this helps.
Jaguar MKII 3.8 manual. Triumph Vitesse 2.0l MK2. Triumph Bonneville 650 chop.
