Has anyone got their heated windscreen replaced via their insurers even though the windscreen isn't cracked or chipped, only the heating element broken?
I rang up my insurers esure who put me through to autoglass, who informed me that the element isn't covered through the insurance policy but they'd happily replace it for £356!
Heated windscreen replacement
04 XJ 3.5 SE Midnight Black | 04 S-Type 2.7d Sport Ultraviolet Blue
Re: Heated windscreen replacement
Just a thought before you contemplate changing the screen, have you checked the fuse and also the connector for the side that is not working.
2012 XKR, Black pack, Aero pack, Speed pack
Past:-87'XJS 3.6L, 93'XJ40 3.2L gold, 95'XJ6 4.0L sport, 00'XJ8 3.2L sport, 2005 XK8 4.2L, 2009 X150 5L Portfolio coupe, in that order and enjoyed all of 'em.
Thanks for the heads up; just been out to check. They look ok, but the fuses are unlike anything I've ever come across before. Might it be worth changing them just in case?
No need to change if they check out with a meter. Also worth checking you have power at the screen connector.
