LWB rear door chromes
Moderators:robv12, DavidEm
simonx308
Postby simonx308 » Mon May 28, 2018 8:50 am
Sorry if this had posted before but I can't find any info. I have a 1998 LWB. The chromes on the rear doors are bulging out, due to rust underneath. Can the chromes be removed and the rust treated or are new doors required?
1998 x308 lwb 4.0
robv12
Re: LWB rear door chromes
Postby robv12 » Mon May 28, 2018 11:15 am
do you mean the door frames , or the door to window waist seals??
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
Andy P
Postby Andy P » Mon May 28, 2018 11:18 am
Hi simonx308,
I think these are the parts your referring to,item No 6.
Page is located at
https://www.jaguarclassicparts.com/uk/j ... annel-rear
They do come off but be very careful because they can kink quite easily.
In the X308 Workshop Manual the only reference to the rear door waist seal is on page 2191 to 2193:
Removal:
10. Exercising care to avoid damaging paintwork, remove door
outer waist rail and rear outer finisher.
Installation:
7. Fit and fully seat door outer finisher.
8. Fit and fully seat door outer waist rail.
9. Fit cheater inner finisher.
Hope that helps mate,
Enjoy your X308,
Take Care,
Andy 8)
robv12
Postby robv12 » Mon May 28, 2018 11:35 am
£279 and £266 each plus vat, OUCH
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
56 X150 XK
robv12
Postby robv12 » Mon May 28, 2018 11:36 am
EuroJag for a pair of used ones??
simonx308
Postby simonx308 » Mon May 28, 2018 11:49 am
Cheers guys. I did mean the door frames. The chromes themselves are in good condition. The actual frame under the chromes is rusting and pushing the chromes out. Is the door one piece or can you buy new frames ?
1998 x308 lwb 4.0
Andy P
Postby Andy P » Mon May 28, 2018 1:22 pm
Hi again simonx308
Found this info on page 2034 of the X308 Workshop Manual.
Each front and rear door consists of a welded, mild steel inner frame and an outer panel. The outer panel is welded to the
waist rail and cheater of the inner frame, then bonded and clinched to form the door assembly. Cosmetic PVC bead is
applied to all clinch joints. Sponge rubber primary and secondary seals are mounted on the doors. Internal insulation is
provided by a foam water shedder attached to the door by double-sided adhesive tape. Front and rear door armrests are
secured by internal and external screws to support brackets riveted to each door frame. All external armrest securing
screws are concealed. Each door casing complete with door pocket is secured to the door by clips and screws. Multi-plug
connectors facilitate connection of the electrical harness to guard lamps, window lift switches, speakers, external mirrors
and regulator, all of which are accommodated within the doors.
I don't think you can buy just the frames.
If you can't repair them then second hand ones will have to be sourced I'm afraid.
Hope that helps.
Good luck,
Andy :)
simonx308
Postby simonx308 » Mon May 28, 2018 3:51 pm
Thanks for the help Andy. Looks like it's a pair of new doors then. Or good second hand, if I can find any.
Simon
1998 x308 lwb 4.0
Tattyhead
Postby Tattyhead » Sun Jan 13, 2019 8:21 pm
How did you get on with replacing the chrome trims?
I own a 2002 LWB and one of my rears is pushing up.
Did you find much corrosion on the door?
