Hi All
Unfortunately I have misplaced a spanner from the Jag tool set having disconnected my battery - it's the one in the 1995 set between the 1/2 " and the tiny one - no doubt it will turn up when I don't need it, but in the meantime I'll need to get another as none of my non-Jag spanners appears to be the right size. Can you just let me know the size as I don't want to buy a whole set.
David/Paul - I'm thinking that you'll be able to help me on this one.
thanks very much
Richard
Jaguar Tool Set - Spanner Missing
Richard
Re: Jaguar Tool Set - Spanner Missing
In my 1986 set the smallest are 9 & 11 mil and 7/16 & 3/8.
Alan
Alan
That's so OCD Rich - I bet this is causing you sleepless nightsUnfortunately I have misplaced a spanner from the Jag tool set having disconnected my battery - it's the one in the 1995 set between the 1/2 " and the tiny one - no doubt it will turn up when I don't need it, but in the meantime I'll need to get another as none of my non-Jag spanners appears to be the right size. Can you just let me know the size as I don't want to buy a whole set.
1994 Jaguar XJ40 Sovereign
2003 Jaguar S-TYPE R
2006 Jaguar XJ Sovereign TDVi
2010 BMW E92 3 Series Coupe
Past:
1996 Daimler Six LWB
1985 E28 BMW M535
Past:
1985 E28 BMW M535
ha ha, no it's a bit more than my being a tad OCD...i currently can't reconnect the battery without using my adjustable pliers, so not ideal.
Richard
The tool box for my Celebration went AWOL with a previous owner so I haven't even got one! That is causing me a bit of OCD!!
It's a 10mm!!!
Richard
Sounds like it went metric on later cars like yours. I have a dedicated spanner for my battery terminals which is 1/4" Whitworth (the same as 5/16" BSF) which is a strange size at 13.34mm.
My '88 has a generous mix of AF and metric all over the place, which is fine if you have spanners and sockets of both kinds, the problems happen when less caring owners use the wrong one or worse an adjustable spanner and the edges get rounded off. As the saying goes, if you use a metric spanner and it slips you risk damaging your nuts
At work (Railway), Whitworth rules completely although even these vary as for the same thread, as they made the nut and bolt heads smaller during the war to save metal
I was thinking the very same thing of the previous owner of my car! I thought of trying to find the correct tool kit and I won't even use the bloody thing! Talk about anal!The tool box for my Celebration went AWOL with a previous owner so I haven't even got one! That is causing me a bit of OCD!!
Mac
Previously: 1989 V12 XJ-S Coupe
The tool kit for your car had gone missing before I got it 15 years ago!I was thinking the very same thing of the previous owner of my car! I thought of trying to find the correct tool kit and I won't even use the bloody thing! Talk about anal!The tool box for my Celebration went AWOL with a previous owner so I haven't even got one! That is causing me a bit of OCD!!
So, it was one with a tool kit? I wonder which part number?The tool kit for your car had gone missing before I got it 15 years ago!I was thinking the very same thing of the previous owner of my car! I thought of trying to find the correct tool kit and I won't even use the bloody thing! Talk about anal!The tool box for my Celebration went AWOL with a previous owner so I haven't even got one! That is causing me a bit of OCD!!
Mac
