Front Lower Ball joints
I am currently rebuilding my front suspension on my 1990 XJS v12, am i correct in thinking that due to the ball joint having a tapered shaft you can tighten the nut to its maximum or is there a limit on how much poundage you put on it.
Re: Front Lower Ball joints
Hi - there is a torque setting for this but I can't remember what it is off the top of my head.
As a safety related component I would be inclined to tighten it to the correct torque. Too little and it may work loose and chatter, ultimately falling off I guess although you should be using a new nylon nut which should prevent that. Too tight will put excess strain on the stub and it may fail with obvious dangers.
Thanks David,
I am using a new nylon nut so it shouldn't work loose, do you know where i can find out the torque setting please.
Hi - I just looked it up in the Repair Operation Manual and it should be 55 lb ft or 75Nm
Hope that helps
Hope that helps
Thank you David for your help, very much appreciated.
Users browsing this forum: No registered users and 16 guests
