Front Lower Ball joints
jimmy1945
Postby jimmy1945 » Tue Oct 31, 2017 5:06 pm
I am currently rebuilding my front suspension on my 1990 XJS v12, am i correct in thinking that due to the ball joint having a tapered shaft you can tighten the nut to its maximum or is there a limit on how much poundage you put on it.
davidr
Re: Front Lower Ball joints
Postby davidr » Tue Oct 31, 2017 10:00 pm
Hi - there is a torque setting for this but I can't remember what it is off the top of my head.
As a safety related component I would be inclined to tighten it to the correct torque. Too little and it may work loose and chatter, ultimately falling off I guess although you should be using a new nylon nut which should prevent that. Too tight will put excess strain on the stub and it may fail with obvious dangers.
jimmy1945
Postby jimmy1945 » Wed Nov 01, 2017 12:31 pm
Thanks David,
I am using a new nylon nut so it shouldn't work loose, do you know where i can find out the torque setting please.
davidr
Postby davidr » Wed Nov 01, 2017 10:10 pm
Hi - I just looked it up in the Repair Operation Manual and it should be 55 lb ft or 75Nm
Hope that helps
jimmy1945
Postby jimmy1945 » Fri Nov 03, 2017 12:34 pm
Thank you David for your help, very much appreciated.
