I need to replace the bearing and hub on the front right of my 1990 XJS.
The bearings are easy to track down, however the hubs are not and new from jaguar, as all things jaguar, are expensive!
Any advice on how to track down a non cracked hub would be appreciated.
Best
Kim
FRONT WHEEL HUB
FRONT WHEEL HUB
Try this outfit, I have not used them, but they seem to specilise in hubs and diffs
http://www.jagaxles.com/
FRONT WHEEL HUB
Kim, I'm assuming you mean the stub-axle? grooved by a spinning outer bearing. If its the whole assemble containing the wheel studs I would think a breaker is the best bet. Yours will have the ABS type
Either way, lots of good advice in Kirby's book on how to set it up properly, and how to remove the axle if you need to. See 'Technical' at the top of the page.
Pop
Pop
FRONT WHEEL HUB
Kim,
Tks for your email. I'll post here rather than email you as others may be interested.
If you mean the hub housing, then they are the same on all late XJSs up to the end of production, and also the same as late Series III XJ12s with ABS.
You can't buy them new at the moment anyway, so I think you're going to have to go down the breakers route. Try Eurojag or Graham Hallett @ Grublogger. It's worth giving Clarkes of Sussex a ring also as they often have cars in which they use for parts for the cars that they sell.
Good Luck
Good Luck
FRONT WHEEL HUB
Many thanks for all your advice.
I managed to track one down at Eurojag.
All the best
Kim
All the best
Kim
