FRONT WHEEL HUB
kimwit
FRONT WHEEL HUB
Postby kimwit » Wed Sep 05, 2007 5:20 pm
I need to replace the bearing and hub on the front right of my 1990 XJS.
The bearings are easy to track down, however the hubs are not and new from jaguar, as all things jaguar, are expensive!
Any advice on how to track down a non cracked hub would be appreciated.
Best
Kim
nigel1
FRONT WHEEL HUB
Postby nigel1 » Thu Sep 06, 2007 11:51 am
Try this outfit, I have not used them, but they seem to specilise in hubs and diffs
http://www.jagaxles.com/
poprivet
FRONT WHEEL HUB
Postby poprivet » Thu Sep 06, 2007 12:11 pm
Kim, I'm assuming you mean the stub-axle? grooved by a spinning outer bearing. If its the whole assemble containing the wheel studs I would think a breaker is the best bet. Yours will have the ABS type
Either way, lots of good advice in Kirby's book on how to set it up properly, and how to remove the axle if you need to. See 'Technical' at the top of the page.
Pop
FRONT WHEEL HUB
Postby ptjs1 » Fri Sep 07, 2007 5:29 pm
Kim,
Tks for your email. I'll post here rather than email you as others may be interested.
If you mean the hub housing, then they are the same on all late XJSs up to the end of production, and also the same as late Series III XJ12s with ABS.
You can't buy them new at the moment anyway, so I think you're going to have to go down the breakers route. Try Eurojag or Graham Hallett @ Grublogger. It's worth giving Clarkes of Sussex a ring also as they often have cars in which they use for parts for the cars that they sell.
Good Luck
kimwit
FRONT WHEEL HUB
Postby kimwit » Mon Sep 10, 2007 9:21 pm
Many thanks for all your advice.
I managed to track one down at Eurojag.
All the best
Kim
