interchanging parts
peterjohn77
interchanging parts
Postby peterjohn77 » Sat Jun 02, 2007 9:56 pm
Hi Folks
I note that there are parts from later model XJSs that would fit my 78 XJS but the part number has changed. Is there any definitive summary or look-up table that lists these interchangeable parts?
Peter :D
kelsham
interchanging parts
Postby kelsham » Sun Jun 03, 2007 4:48 pm
Hi I have both a Pre HE and later cabriolet, many parts were changed on the later cars, the engine F.Injection, cpu, wheels, tyre size, in your case later gm gearbox, axle ratio. Do I need to go on? best to order by the old part No. The supplier should tell you if the part will fit regards Kels
poprivet
interchanging parts
Postby poprivet » Sun Jun 03, 2007 4:54 pm
Have you tried putting the part number in the David Manners Website It usually comes up with an alternative correct part number if available.
Pop
