You may have already done this. But my x300 has a nasty habit of not starting - especially just before a JEC event...
Anyway, the CPS (Crankshaft Position Sensor) keeps failing. It's very unusual to have the number of failures I have experienced. But they will prevent the car from starting or cranking when failed.
Cheers, Rob.
1996 X300 AJ16 4.0 not starting
- robgx300xjr
1997 XJR X300 Manual
Re: 1996 X300 AJ16 4.0 not starting
EML out , means no power to the ECU.
Thanks for the responses. The crank position sensor has been replaced just over a month ago.
ECU was out - we have found the culprit!!! Water had been traversing through the cabling into the ECU and then exiting at the base!!
A replacement ECU was sort from ebay for £70 and seems to be doing the job so far!
Cheers, Rich
Cheers, Rich
1994 Jaguar XJ40 Sovereign
2003 Jaguar S-TYPE R
2006 Jaguar XJ Sovereign TDVi
2010 BMW E92 3 Series Coupe
Past:
1996 Daimler Six LWB
1985 E28 BMW M535
Past:
1985 E28 BMW M535
That`s had it, Rich. Broken!
Present it to the local Council in the approved and tested manner!!
If the check engine light goes OUT, the ECU is still asleep and you will have no permission to crank, sound familiar
told ya!!
yep its beyond its use by date , in the skip with that one
told ya!!
