Hello all.
Jaguar S type diesel 2007.
Warning indicator permanently shows "Boot Open" although the boot lid is securely shut.
I did read that this can be caused by a chafing of the wiring loom as it enters the offside boot lid hinge. I have checked this area with the hinge cover removed (photo attached) and cannot see any damaged wires.
Can any members advise where to look next?
Once in a while the "Bonnet Open" light will also flash on(bonnet securely shut) which seems to point to a more general fault.
Any advice would be much appreciated.
Trevor.
Boot open light on
trevor.pocklington781
Re: Boot open light on
Damaged wiring on the boot hinge doesn't necessarily show visually. It's quite common for breaks to occur inside the plastic insulation. Hence, to eliminate it as a possible cause, it will be necessary to use a multimeter or similar to test the continuity of the wiring. Similarly, whilst using a multimeter in that area, test the boot light switch itself to ensure it's working correctly. Mike.
