Front axle suspension Rapid wear of rubber bushes
Moderators:iRS, Art1012
XJ12HE
Postby XJ12HE » Fri Nov 01, 2024 1:05 pm
Hello all,
On my E-V12 2+2 I have to replace the rubber bushes on the front lower wishbones at least once a year.
Within a year the lower wishbones move backwards and crush the rubber beads of the rear bushes. The front suspension then becomes noticeably uncomfortable with cracking noises.
During assembly, the outer washers have a stop due to the smaller bore and are limited by the castellated nut, which is tightened to 13 mKg.
It makes no difference whether I fit the front or rear bushes first. The result is always the same.
I have no idea what I could do differently or better to prevent this premature wear.
I must also mention that I have set a very large amount of caster.
I have found that the poly bushes wear the fastest. During the last repair I fitted the Barratt rubber-metal bushes. They seem to be more durable,
I hope you can give me an explanation and a fitting method for a permanent remedy.
Michael Gleiss
Re: Front axle suspension Rapid wear of rubber bushes
Postby ptjs1 » Fri Nov 01, 2024 9:36 pm
Michael,
Have you been fitting proper genuine Metalastik bushes?
There are plenty of cheap bushes around for as little as £2.75. Many of them are rubbish and quickly wear out. Proper Metalastik ones will be at least £12.50 each.
XJ12HE
Postby XJ12HE » Sat Nov 02, 2024 9:53 pm
Hi Paul,
I have the expensive ones for €26.00 each from Barratt
Michael
Postby ptjs1 » Sun Nov 03, 2024 1:00 am
Hi Michael,
If you're knocking out genuine metalastik bushes in 12 months, you might want to start looking at the other elements such as:
- Wheel bearing play
- Wheel balance
- Toe alignment
- Camber alignment
- Caster alignment
- Brake grab /play
- Balljoint play
