My 1980 S3 xj12 is having some problems. I replaced the water temp sensor over the weekend, took her up the motorway for a 60 mile drive with no problems, Monday morning came and she started but stopped a few mins later, got her started a few more times but now she's not firing up. I put the original sensor back on with the same effect.
I'm sure it's something to do with the ignition amp/ power amp or the ECU. does this sound write? could it be an injector problem? She has the original type opus ignition amp! I've heard that they're not very reliable.
Any Ideas?
Paul K
1980 XJ12 having problems
Moderator:LJR
Could certainly be the Opus ignition system.
Do you have a spark? Insert a spare, gapped plug in the easiest spark plug lead to remove and then resting this on a good metallic part of the engine observe the spark (?) when cranking. If you have a good solid spark at the plug, it likely isn't the amp. Absence of spark doesn't necessarily implicate the amp, it could be the coils, the rotor arm, distributor pick up etc.
Al McL
Glad it's working again!
I think Barratts do a complete replacement for the Opus system (Bob Bate mentioned it in a very long drawn out series of articles in the club magazine last year) but as mine has the later Lucas CEI system, I haven't had to go down that route.
Al McL
