Receiver Drier - Seals
Moderators:robv12, DavidEm
gjh007
Postby gjh007 » Tue Oct 17, 2023 8:11 pm
I have a leaking receiver drier in my 2000 X308 XJR. A new drier isn't a problem but I can't seem to find which seals are required. Can anyone point me in the right direction? Many thanks!
gjh007
Re: Receiver Drier - Seals
Postby gjh007 » Mon Nov 27, 2023 7:22 pm
Just to answer my own question after some research - Jaguar no longer stock some of the required o-rings, and they no longer have the information on where each o-ring is used anyway. The solution was a bunch of generic o-rings and sensible guesses as to which fitted where.
2000 X308 XJR
2009 X-Type 2.2d auto estate
andypryce
Postby andypryce » Mon Nov 27, 2023 10:05 pm
Good result, if possible post a link to the source of the O rings in case others look in future.
XF Sportbrake 2020 / XK8 1998
gjh007
Postby gjh007 » Sat Dec 23, 2023 4:27 pm
Sadly I can't take credit for the work or guesses as to which O-ring went where. The job was done by a local Jag specialist and he sourced a generic pack of O-rings from ebay. Still, all holding up well so far, so I'm pleased with the result.
2000 X308 XJR
