Hi all,
Can anyone help with the attached photo as I need 4 replacement screw covers but have no idea where from - Can anyone help please with size and where to obtain replacement
Jaguar XK 2006
Thank you in advance
2006 Jaguar xk help with screw cover replacement
leelane588
Re: 2006 Jaguar xk help with screw cover replacement
If I need parts I always start here: https://parts.jaguarlandroverclassic.co ... xk8-parts/
Often the part you need is still available from Jaguar and can be ordered through your local dealer. Failing that you will have a part number you can then use to search for on the internet. If Jaguar cannot help then one of the breakers probably can.
2001 XK8 4.0 Coupe in Quartz
I suspect that the part number for the components you need is C2S32760. The plastic caps are still listed by Jaguar at 81p + VAT apiece. Mike.
leelane588
They are for setting the level of the tail gate to the bodywork if broken maybe not slamming the tailgate down when closing in future.
JOHN
JOHN
Don't try to defy the law of physics
Understear is when you hit the wall with the front of the car, and oversteer is when you hit the wall with the rear of the car horsepower is how fast you hit the wall, torque is how far you take the wall with you.
