Hello,
The above pipe has rusted and split during an MOT test. My local garage can't find a replacement part for it and are even struggling to get pipe of the correct bore to fabricate a replacement. (I've checked JLR Classic and they don't carry this part.) Any information would be gratefully received. My X350 is a 2003 3 litre V6.
Thanks,
Dave Edwards.
Pipe between booster and modulator
Re: Pipe between booster and modulator
Dave, of some sort
What is the part number? You mentioned it goes from the booster, so presumably it's a vacuum pipe of some sort?
DavidEdwards
Hi Paul,
It's a brake fluid pipe that goes to the modulator - this being the magic box which appropriately directs hydraulic pressures to the four wheels.
I've got a bit lost as regards the part number, but I think it might be C2C28015 or C2C28016.
Thanks for your time,
Dave.
Dave.
Dave,
Yes I see. It's not a pipe from the booster. It's the twin hydraulic pipes from the master cylinder to the modulator. The correct number for your RHD car is C2C28016.
I suspect you'll need to either buy a used pair of pipes, or else fabricate yourself. There's a few complex bends but nothing a garage couldn't do for you simply, with your old pipes as patterns, if you don't have a flarer or a bender. You could use the fittings from your old pipe.
Try autoreserve or Eurojag, you might get lucky.
XF Sportbrake 2020 / XK8 1998
I wonder if a hose maker like Pirtek could make a copy. AFAIK it's a standard large bore brake hose and flare, possibly for (metric) commercial vehicles such as lorries. I think that's 1/4"=6.4 mm bore The other brake lines are standard 3/16"= 4.8 mm.
See here.
See here.
1986 XJ6 Sovereign Series III
1991 XJS V12 "facelift"
2021 I-Pace SE
2021 I-Pace SE
DavidEdwards
Many thanks for all your replies. In the end I did find a local pipe fabricator who used the original fittings on quarter inch pipe and my x350 finally has a clean MOT!
Thanks for the update Dave.
Good to know you got it fixed and back on the road.
Take care.
Take care.
