Selector leak
Moderator:LJR
harvest
Selector leak
Postby harvest » Tue Jun 13, 2023 9:27 pm
Hi if anyone could advice. I have a xj6 series1 with a borg Warner box
I've always had a small leak from the passenger side of the box, I'm sure it's the gear selector shaft. My question is.will the box have to be removed to replace the small seal. Or am I better keep wiping the small drop of oil of the exhaust which creates alot of smoke after a weekπŸ˜ƒπŸ˜ƒπŸ˜ƒ as the box works perfectly fine. Many thanks tony
Dave Eynon
Re: Selector leak
Postby Dave Eynon » Wed Jun 14, 2023 5:45 am
Hi Tony, I have exactly the same issue with mine. I do recall changing the seal in situ years ago but the leak soon returned. As it isn't an issue for normal usage I have opted to leave mine alone. I would be interested to hear what others have done or not done.
Dave E
Gwynedd. N Wales.
X-type 2.5 Estate
XK8 Coupe
XJ 4.2 S1
Daimler 2.5 V8
harvest
Re: Selector leak
Postby harvest » Sat Jun 17, 2023 8:01 am
Thanks for reply. I think il be leaving it as its not causing a problem outer that a quick wipe before I start. Cheers
