Hazard switch stuck
davidr
Hazard switch stuck
Postby davidr » Sat Oct 29, 2022 6:05 pm
On the way back from the Kemble Breakfast Meeting in my 2000 XKR today I wanted to flash my hazards to thank a tractor that moved over. Only trouble was they wouldn't turn off again! The switch was stuck!
Thankfully I was very nearly home so I tried to keep my head down going through the village with the hazards on.
The switch appeared to be physically stuck in so I put a hook behind it and pulled it out which turned the hazards off.
I guess I'll have to pull the centre console out to get at the switch pack.
Is the switch repairable? Will I be able to replace it? Do I have to replace the whole switch pack?
andypryce
Re: Hazard switch stuck
Postby andypryce » Sun Oct 30, 2022 12:18 am
Hopefully just the spring which should be a fairly easy fix.
XF Sportbrake 2020 / XK8 1998
steve_m
Postby steve_m » Sun Oct 30, 2022 9:47 am
A gentle spray with contact cleaner or WD40 around the edges?
Postby mike020150 » Sun Oct 30, 2022 11:32 am
The whole row of switches is supplied as one unit (approx £300 from Jaguar) so a can of contact cleaner seems like the way forward! Mike.
Astromorg
Postby Astromorg » Sun Oct 30, 2022 11:55 pm
General Jaguar Forum history records the sticking Hazard switch to be a not uncommon occurrence, but the reported successful solutions range from:
Easing it out with (eg) a credit card and/or spraying with WD40, silicone spray, etc
Clearing debris with a feeler gauge or stripping the switch and cleaning it
Reducing the torque on the screws holding the switch assembly to reduce distortion or file the frame or the switch to increase clearance
Replace the switch assembly with new or (cheaper) used item, either of which may well fail in the same way :(
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
davidr
Postby davidr » Mon Oct 31, 2022 12:18 pm
Thanks all for your responses. I'll take the switch pack out later and see what we have.
andypryce
Postby andypryce » Mon Oct 31, 2022 8:23 pm
If you’re going to start squirting I would go with contact cleaner, as that doesn’t leave any residue, unlike WD40 etc.
davidr
Postby davidr » Mon Oct 31, 2022 10:19 pm
I managed a little time in the workshop this evening and soon had the switch pack out. When you've done it before and have the right approach it takes less than 10 minutes to remove the centre console and remove the switch pack. The potentially tricky bit is removing the plastic gearshift surround without breaking the fragile plastic tabs. My technique is to use an old credit card to push the tabs back whilst gently levering up with a plastic trim tool.
This was what I had on the bench
The switch pack comes out as whole. On the back are 5 screws. Removing those and gently prising the small plastic tabs out allows the back to be removed.
Taking the back off reveals a single circuit board with a row of small switches, lamps and LEDs. This explains why the pack is sold as a whole and not individual switches - it is just one part!
Most of the volume of the pack is taken up with the mechanical part of the switch that transfers the motion to the small switches on the circuit board.
Looking more closely it was easy to gently prise the front bezel off the hazard switch allowing the main body to be pushed through and removed.
There was what I guess was once white grease that had now dried out and was gumming things up. A clean with some electrical contact cleaner soon had it moving freely. I gave the other switches a clean whilst I was there.
Putting it all back together again didn't take long but I took the precaution of trying the switch at every stage just to make sure it continued to work. Pleased to say that it did!
Here it is assembled again with the hazard flashers on
And just to prove it worked, here it is turned off again.
The whole job took about 45 minutes including taking the centre console etc out and putting it back in again and cost exactly nothing - result!!
andypryce
Postby andypryce » Tue Nov 01, 2022 12:27 am
Excellent well done!
Postby mike020150 » Tue Nov 01, 2022 10:32 am
Great, you'll be able to spend the £300 saved on a tank of super unleaded! :lol: Mike.
JimMann
Postby JimMann » Tue Nov 01, 2022 10:33 am
Hi David, please send me the high-resolution photos via WeTransfer and I can turn your fix into a top tip for the column!
Jim
Jim Mann
Banchory
davidr
Postby davidr » Tue Nov 01, 2022 11:56 am
Thanks Andy and Mike. The £300 "saved" doesn't go very far at the pump these days!
Jim - I've sent you those pictures
Best wishes
David
royking999375
Postby royking999375 » Tue Feb 14, 2023 10:10 am
I have just come across this item and having experienced the problem can only sympathise. The switch on my 2003 XKR failed just prior to an MOT, however the examiner advised that the issue needed to be resolved before the next MOT was due.
Having extracted the switch pack I discovered, as did you, that the tiny switch on the PCB incorporated the return mechanism and in my case had lost the ability to push the hazard switch to the off position. However a chance discussion with a fellow car enthusiast in my village established that he was an electrical engineer by trade and offered to help. He sourced a replacement switch (only available in multiples of 10) adapted it to accommodate the dimensions of the XKR and cured the problem. I originally tried to source a replacement switch bank, but was unable to find one due to there being many options installed across the life time of the marque.
Would anyone want details of the micro switch part number I am sure I can source it through my kind neighbour.
Postby mike020150 » Tue Feb 14, 2023 10:28 am
It sounds like it would be a good idea to share the part number and source of the switch here to help fellow sufferers with this problem. :) Mike.
royking999375
Postby royking999375 » Tue Feb 14, 2023 11:30 am
I do not have it to hand, as I did not source it but will make enquiries and post when information is to hand
