Cromer plastic seat lever X-150
ray.kite718851
Postby ray.kite718851 » Thu Jul 21, 2022 10:15 am
The sleeve holding the chromed plastic lever has snapped. I’ve found the replacement part at SNG but removing the broken sleeve is a bit of a problem. Has anybody found a swift solution?
Re: Cromer plastic seat lever X-150
Postby mike020150 » Fri Jul 22, 2022 10:12 am
The chromed lever is only held by a single screw which you should be able to access by pivoting the piece to which it attaches. Mike.
ray.kite718851
Postby ray.kite718851 » Fri Jul 22, 2022 10:16 am
O I C. I hadn’t realised it was a screw. I thought it was a permanently attached spindle. I’ve managed to get most of the broken sleeve off. It appears to have been glued.
ray.kite718851
Postby ray.kite718851 » Fri Jul 22, 2022 12:39 pm
Again, many thanks Mike. I’ve now pretty much bared the screw and am awaiting the part (due today).
Ray
ray.kite718851
Postby ray.kite718851 » Fri Jul 22, 2022 12:59 pm
Job done.
Postby mike020150 » Fri Jul 22, 2022 4:17 pm
Excellent! I was mildly concerned in case the pivot part had become damaged because that is not available as a spare part. Mike.
