2003 XKR fault codes c1175 c1165 HELP
vinniexkr
Re: 2003 XKR fault codes c1175 c1165 HELP
Postby vinniexkr » Sun Jun 12, 2022 7:49 pm
Once the car has been repaired I would be happy to do a story on it, I would then have all the relevent information, prices for parts and labour ect, the car once sorted would be worth about £12-£14000.00.
Vince
JimMann
Postby JimMann » Mon Jun 13, 2022 9:30 am
Hi Vinnie,
I do think the story needs to be told, especially the tortuous (and expensive) route to an eventual solution. Once you are ready, you will find my email address at the top of the Modern XK pages in the JE magazine. Let me know if you need any help to put it down on paper and get me some photos.
Good luck.
Jim Mann
Jim Mann
Banchory
vinniexkr
Postby vinniexkr » Mon Jul 04, 2022 4:08 pm
I now have the XKR back at home with no fault codes,. the journey to find out the problem has been rather tortures,
In the end it took 43 hours work (£216.00 PH) changing, swapping, fault finding and putting on many new parts that were not needed.
New ABS module, rear nearside reluctor ring (even though the fault was stationary) new wheel bearing (nearside as good practice when rear hub is removed) new back plate as it was rusted, new hand brake cable as this had a kink in it, various seals, pin-spring, seals ect.
I asked them to put on new front tyres as in their report it showed age cracking, unfortunately they changed the rear tyres 7mm tread! so now have 4 new tyres ! I asked for an oil change and a water leak at the back of the engine sorted, (new pipe and valve) Investigate front and rear fog-light not working, now ! they charge a fee to find the faults at £216 per fault, this can work out at a lot of money to find the fault if its only a 5 min job. The fault with the ABS took a long long time to sort, in the end it cost heavily discounted £4308.80.
The actual fault !! a faulty wire !?
Astromorg
Postby Astromorg » Mon Jul 04, 2022 5:53 pm
Mmm! A broken wire, yet all that unnecessary work and parts replacement at a huge cost, when checking the relevant wiring for shorts or breaks is the first requirement stated By Jaguar
Jaguar's official take on Fault Codes C1155 and C1165 is as follows:
Seems to me you've got a good case to go back to some of the would-be repairers and claim some rebate.
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
andypryce
Postby andypryce » Mon Jul 04, 2022 8:37 pm
For all that work, at ( I presume) a main dealer, then I don't think 4k is excessive to be honest. My local main dealer charged me over £500 for a service on the XF, which as far as I can tell was essentially oil and filter plus an unwanted video of what they were doing! Now it is out of warranty I have no intention of going back...
XF Sportbrake 2020 / XK8 1998
vinniexkr
Postby vinniexkr » Fri Jul 08, 2022 8:40 pm
For the amount of work and parts supplied no, not to much, but ! it did not need the parts and the wiring fault should have been diagnosed.
They said they swapped two pins around, from the sensors to the module ! I do not get that !! they said they had isolated the wiring and put in a separate wire from the sensor to the module but still the same problem, how then can it be, if its isolated it is not connected, how can the original wire suddenly work when the pins are switched when before it was isolated ? I am very confused !! wheres the brandy !!
vinniexkr
Postby vinniexkr » Wed May 10, 2023 7:13 am
I am now having to send the XKR back to the garage as the wheel bearing that was fitted is humming like a gooden !!
The car has only done a few miles since it was fitted, I jacked the car up and it seems very tight on the hub !!
Once fixed it is going, I have had enough of it, just need to know what it is worth ?
vinniexkr
Postby vinniexkr » Sat Jul 15, 2023 1:06 pm
The XKR is still down at Jardine Jaguar in Tonbridge, they have not been able to get a crush washer !
They changed a good wheel bearing whilst the hub was out because the say "its good practice" !! the new one
lasted only a few miles !! it did not need replacing, the hub did not need to come off, the reluctor ring did not need changing either.
Two months they have had the car.
andypryce
Postby andypryce » Sat Jul 15, 2023 7:27 pm
So frustrating!
vinniexkr
Postby vinniexkr » Thu Jul 20, 2023 8:59 am
I do not know what is going on at Jardine Jaguar in Tonbridge !!
I was called yesterday 19th July by Jardine to say the XKR was ready to be picked up.
I arranged a lift from my place at Mark Cross in East Sussex to Tonbridge in Kent, I was dropped of at Jardines at about 5pm.
I went to the service section and said that I was picking up my car, "ok we will get the car round for you" !
I waited at least 15 minuets when the manager came out to see me, the last time we met was last year when the car went in with the ABS fault.
You know about what happened that time !! "Hi Mr Tarling" said Mark, he then said " I am very angry at the moment and embarrassed ! I am afraid I cant let you take the car" Why I said ?? he then went on to say that there is a possible safety issue and as such he couldn't let me take the car, he was not sure exactly what the problem was but he would know more tomorrow !!
I asked how this could have happened, the car was allowed to leave the workshop, I was called to say the car was ready but now this !!
He was very sorry but this has now got to a point where I am at a total loss as to what the hell is going on there at Jardine.
I told him how the experience of last years visit has being playing on my mind and that I had not been given a proper explanation of what wiring problem caused the ABS fault, I said that the parts that were fitted but did not cure the problem I should not have paid for, I paid the invoice because I just wanted to get the car back and draw a line under the whole thing.
The fact the car was back because they changed a good wheel bearing because it was "good practice if the hub if removed" just makes it even worse, I have now made it clear I want a full explanation as to what was the wiring fault last year and why it was not picked up before they started replacing components that were not faulty.
I had to walk away for a bit to calm down, they then had to arrange a lift back home for me as mine had long gone ??!!
What next ???
Postby mike020150 » Thu Jul 20, 2023 9:26 am
Rather like a restaurant where the quality of meals rests on the chef's shoulders, a dealer's reputation hangs on the abilities of its staff. Lose good staff members and your reputation will follow. What a shame that owners' views of Jaguar depend on the performance of their dealers! :( Mike.
andypryce
Postby andypryce » Thu Jul 20, 2023 12:32 pm
What a mess, I hope you get sorted soon. Definitely look for a good independent garage, even if it's not a jaguar specialist.
vinniexkr
Postby vinniexkr » Sat Jul 22, 2023 10:40 am
DSC
I now have the XKR back from Jardines of Tonbridge, they sent the car back nicely cleaned which is great.
I will be taking her out later and check all is well.
I asked for an explanation of what the wiring fault was last year and they sent a workshop sheet over to me explaing what the fault was.
It makes no sense to me so I have attached it in the hope of someone being able to make sense of it.
Astromorg
Postby Astromorg » Sat Jul 22, 2023 10:19 pm
Can't say it makes a lot of sense to me either! One can see that they're trying to test in the right areas, but their tests and quality of recording are less logical to me and look scrappy. I certainly don't see that they prove wire continuity. (Edit; But see my later post!)
What they should have been trying to establish was that the two wires from the ABS Module to each of the sensors was firstly electrically continuous from end to end with a less than 5 ohm resistance - Basic test for an electrician - and record it as such.
The next test was to determine any electrical leakage from either of the two wires to ground by measuring the resistance between the wire and ground and requiring a value greater than 10,000 ohms
I can't make any of their records prove those tests were achieved, but I'm ready to be shown what I've missed. (Edit; Again, see my later post!)
We can argue about an intermittent break in a wire only showing up when the wire flexed, but the fault was not intermittent and anyway when things got difficult, they should have tried flexing at the appropriate places while testing. It's a common enough problem, particularly on the front sensors of X100s.
Those tests are what is shown here; they are the published Jaguar instructions for identifying the causes of C1175 (C1165 is the same for its own wires)
2024 XE 300 Sport
andypryce
Postby andypryce » Sun Jul 23, 2023 12:29 am
Goobledygook. At least Astromorg attempts to understand it, better than I could!
