Engine numbers
Moderator:LJR
mt.53227
Engine numbers
Postby mt.53227 » Wed Jun 15, 2022 4:20 pm
I have a Mk2 which has been fitted with a 4.2ltr engine which is meant to have come from a Series II XJ6. I have letters and numbers stamped on the top side of the oil filter mounting which is where I should find the engine serial number, unfortunately they do not correspond to anything I can find. The code is AQ 765,Jaguar 4.2ltr is cast into the block above this point. Can anyone shed any light on this?
Thanks, Malcolm
Re: Engine numbers
Postby mike020150 » Thu Jun 16, 2022 11:07 am
Have you checked the crankcase bellhousing flange on the left side of the engine near the dipstick? On some XK engines, it may be marked there. Mike.
mt.53227
Re: Engine numbers
Postby mt.53227 » Thu Jun 16, 2022 12:36 pm
Thanks Mike I thought I had looked there but will go and have another look
