Fitting rear parking sensors
andypryce
Postby andypryce » Fri Jun 10, 2022 10:42 am
Hi all,
Does anyone have experience of fitting rear parking sensors to a 1998 XK8? I recently fitted a set to my daughter’s 10 year old Mini and was pleasantly surprised how easy it was, did not even need to remove the bumper! I am tempted to try on my XK8 but not sure if it will be so easy?
XF Sportbrake 2020 / XK8 1998
andypryce
Re: Fitting rear parking sensors
Postby andypryce » Fri Jun 10, 2022 11:22 am
Scrub that question, on further inspection going to fit a camera instead, looks pretty simple, will post pics once done.
JimMann
Postby JimMann » Fri Jun 10, 2022 11:56 am
Hi Andy,
Some interesting articles in the Modern XK column you may like to look up, the digital back catalogue is on this website:
January 2020 - fitting parking sensors to an X-100
September 2020 - updating the Satnav in the X-100
March 2021 - fitting a reversing camera in the X-100, after upgrading the Satnav as above
Jim Mann
Jim Mann
Banchory
andypryce
Postby andypryce » Fri Jun 10, 2022 3:05 pm
Many thanks Jim
andypryce
Postby andypryce » Fri Jun 10, 2022 4:45 pm
The article relates to front parking sensors, after some research I am going for a rear camera, will write it up for the magazine once fitted.
JimMann
Postby JimMann » Fri Jun 10, 2022 6:10 pm
Cheers Andy,
An article for the column would be much appreciated.
Incidentally though, the aftermarket parking sensors are suitable for front or rear - in Ron's case, I think he had rear parking sensors already fitted to his car so only needed to fit to the front.
Jim Mann
Jim Mann
Banchory
andypryce
Postby andypryce » Fri Jun 10, 2022 11:11 pm
Ah yes, makes sense. I don’t want to eliminate all the risk from my life though :D
Postby mike020150 » Sat Jun 11, 2022 10:13 am
Hi Andy,
In case you change your mind about fitting rear sensors, I can confirm that it was an easy task when I fitted some, many years ago. The most difficult bit was removing and cutting the rear bumper holes. :) Mike.
andypryce
Postby andypryce » Sun Jun 12, 2022 8:26 am
Thanks Mike, halfway through fitting a camera now, no turning back!
davidf
Postby davidf » Mon Apr 17, 2023 4:11 pm
Even easier than cutting rear bumpers is to fit a rear numberplate frame with sensors set at slight angles. i think mines called Parkmate , but different ones on Google search for about £50. Work well for me.
Andy P
Postby Andy P » Tue Apr 18, 2023 1:09 pm
Thanks for the tip David.
Could be quite a good alternative to drilling holes.
Take care.
Andy :D
