Park Brake Fail
Moderators:Popsjag, J44EAG
steve.pritchard146
Park Brake Fail
Postby steve.pritchard146 » Thu Nov 11, 2021 9:58 am
Hi all,
I have recently developed an parking brake fail and amber warning light on my 2008 X358 2.7d
I can't hear any motors if I activate the parking brake switch although if I push it down I get a chime and a red brake light on the dash comes on briefly in the dash.
Fortunately the brake is in the off position so I can drive the car - please can somebody point me in the right direction for fault tracing.
Thanks very much
Steve
Current:
2001 XKR silver, 2008 XJ Blue, 1986 Land Rover Defender, 1967 3.8S cream
Past:
S500, Porsche 944 Cab, Porsche 928 GT, porsche 944 Lux ,Volvo XC90,Volvo S80 T6,Jaguar XJS v12,Volvo C70,Mini R56 Cooper S,Land rover Discovery, Range Rover V8 HSE
Andy P
Re: Park Brake Fail
Postby Andy P » Thu Nov 11, 2021 12:24 pm
Hi Steve,
I'm afraid you have posted in the wrong section.(PERHAPS A MODERATOR CAN MOVE IT TO THE X350 SUB FORUM)
You need the X350 forum,here's the link to that Quite a lot of info on the electronic parking brake:
viewforum.php?f=285
Hope you get it sorted.
Take care.
Andy :D
steve.pritchard146
Re: Park Brake Fail
Postby steve.pritchard146 » Thu Nov 11, 2021 3:40 pm
Doh! - Thanks Andy, I appear to be blind
Current:
Past:
3.8etypephil
Re: Park Brake Fail
Postby 3.8etypephil » Fri Nov 12, 2021 7:22 pm
Would you describe the symtoms in more detail, and any maintenance carried out immediately prior to the fault manifesting itself. What happens when you turn off the engine and remove the key? What happens if you attempt to set the brake manually, either when the engine is running, gearbox in "D"' for example at traffic lights? And if it sets, what occurs when you press the accelerator to pull away again? The more info, the better your chance of an accurate diagnosis.
Phil
2013 XFR
2008 XJR
andypryce
Re: Park Brake Fail
Postby andypryce » Sat Nov 13, 2021 9:49 am
Do you have a code reader? Which amber light is on? Sounds like handbrake motor issue, but agree more investigation required.
XF Sportbrake 2020 / XK8 1998
steve.pritchard146
Re: Park Brake Fail
Postby steve.pritchard146 » Fri Apr 01, 2022 8:10 am
Hi Andy (sorry slow reply) I can’t remember the code, but I do have a reader and it’s a hall sensor failure.
I’ve actually bitten the bullet and got it booked in with Mike Allen in Swindon who seem to be reasonably respected. As they are dropping the rear subframe I’m getting them to do all the bushes.
I was going to do it myself, but with 3 other ‘project’ vehicles I decided I needed to keep at least one on the road :)
Current:
Past:
PaulGover
Re: Park Brake Fail
Postby PaulGover » Fri Apr 01, 2022 8:28 am
...it’s a hall sensor failure....
As far as I recall, when my handbrake failed, it was the same symptom. The cause was damaged wiring (a common fault, it passes through various grommets; there's also a splice in the loom to contend with) rather than the sensor - so the fix was not a new motor unit!
1986 XJ6 Sovereign Series III
1991 XJS V12 "facelift"
2021 I-Pace SE
steve_m
Re: Park Brake Fail
Postby steve_m » Fri Apr 01, 2022 9:24 am
A different car obviously, but all my parking brake problems vanished when I fitted a new battery.
steve.pritchard146
Re: Park Brake Fail
Postby steve.pritchard146 » Mon Apr 04, 2022 12:56 pm
Well there is no doubt the cars are hugely sensitive to voltage drops however in this case my battery is brand new
Current:
Past:
steve.pritchard146
Re: Park Brake Fail
Postby steve.pritchard146 » Mon Apr 04, 2022 12:57 pm
Yes, I was hoping for a wiring failure but have been categorically told not- they’ve also offered me the part due to be swapped so I was going to have a look inside…
Current:
Past:
PaulGover
Re: Park Brake Fail
Postby PaulGover » Tue Apr 05, 2022 9:02 am
What's annoying about this sort of failure is the bit that broke is merely there to check the rest of it worked; the actual motor probably still works. Given there are several ways to find out if the motor works - listen, watch and try the brakes, it's an unnecessary complication...
2021 I-Pace SE
steve.pritchard146
Re: Park Brake Fail
Postby steve.pritchard146 » Sun Apr 10, 2022 9:38 am
Hi Paul,
Yes, the parking brake works fine as a recent MOT test revealed.
Current:
Past:
steve.pritchard146
Re: Park Brake Fail
Postby steve.pritchard146 » Wed May 11, 2022 12:03 pm
As a follow and closure on this.
I have now had all rear suspension arms replaced and the parking brake actuator done at the same time - all is happiness and light apart from in the bank account department!
Current:
Past:
