Got the new car
pabr639439
Got the new car
Postby pabr639439 » Sun Oct 31, 2021 6:15 am
Hi Everyone, I have got my 2005 XKR convertible 4.2S Home, Very pleased with it, I have not had a lot of time to drive it yet. The only problem it has is it does not have a sat NAV cd in it. I probably wont use it but it is a blank screen. And it spoils the dash look This seems to be a minefield buying off ebay with what will work and what does not, Can anyone help or give the name of a good company that could help me please.
I would post a picture of the car but I do not know how to :(
3.8etypephil
Re: Got the new car
Postby 3.8etypephil » Sun Oct 31, 2021 7:41 am
Unless the screen is turned off via the menu, it shouldn't be blank, it should display whatever function was previously selected. Press the menu button, if it remains blank there is a fault, possibly as simple as poor battery charge. If it lights up and offers options, select one of your choice.
As far as navigation discs go, I have previously purchased new copy discs from various eBay sources without problems, but if copies worry you, used genuine ones are frequently available.
ETA; try using a free image host such as postimages for photos:
https://postimages.org/
Phil
2013 XFR
2008 XJR
andypryce
Re: Got the new car
Postby andypryce » Sun Oct 31, 2021 9:43 am
Hi Paul,
I have a set of 3 2006 discs from my old 2006 XK, I replaced them with newer ones when I had the car. You are welcome to have them as I no longer need them, just send me a private message with your address.
XF Sportbrake 2020 / XK8 1998
Andy P
Re: Got the new car
Postby Andy P » Sun Oct 31, 2021 11:35 am
Hi Everyone, I have got my 2005 XKR convertible 4.2S Home, Very pleased with it.
Hello Paul and welcome to the J.E.C Forums.
Congratulations on getting your car and hope it gives you great pleasure.
I can't help with your problem I'm afraid but sure someone on here will know of a solution.
Enjoy your new car and take care.
Andy :D
Astromorg
Re: Got the new car
Postby Astromorg » Sun Oct 31, 2021 6:33 pm
That's a great(est?) version of the X100 you've got in my skewed opinion :lol: You'll enjoy it enormously.
Sadly the offer of three discs from Andy's X150 model XK will not work in your X100 car :(
The last disc (single disc) issued was, I thought, the one dated 2002 fitted in my own 4.2S at build in 2005 although another member recently showed a picture of one dated 2003. Whatever, the discs are way out of date and of limited use for navigation. More :( . But it will provide an image of an analogue clock that works :) See viewtopic.php?f=63&t=16206 for some photos and general info.
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
andypryce
Re: Got the new car
Postby andypryce » Sun Oct 31, 2021 6:55 pm
Indeed quite right, I was thinking X150 not X100…
If anyone else wants them free to a good home..
JimMann
Re: Got the new car
Postby JimMann » Mon Nov 01, 2021 7:26 pm
Hi Paul, congratulations and welcome to the wonderful world of Modern XK Motoring! I am sure you will be aware, but just in case it hasn't sunk in, the Satnav in the X-100 is worse than a broken watch - its at least correct twice a day!
I would recommend you forget the aesthetics of the X-100 Satnav and instead go for the DIY upgrade to install a suitable Garmin (the 5.5 inch version is best), complete with free for life map updates and Wi-Fi included. From there it is a simple route to also add a reversing camera, which is really cool on an X-100.
There is a step by step guide in the JE magazine of September 2020, but if you would like a copy of the photo instructions provided by the author of that particular upgrade, drop me an email and I will send it on to you. My email address appears at the top of the Modern XK pages of the magazine.
Jim Mann
Jim Mann
Banchory
Lucky
Re: Got the new car
Postby Lucky » Mon Nov 01, 2021 11:09 pm
I don't think the satnav in the X100 is quite as bad as Jim makes out but it is a far cry from more modern systems. You often find yourself driving on new roads that the satnav doesn't think exist, and to set a destination I often end up finding it on Google Maps on the mobile and then finding the nearest position on the satnav - exactly what you would expect from maps that are 20 years old. However, that aside, it works if you want to keep the originality, but the upgrade to a Garmin system that Jim mentions looks achievable if you are a practical sort of person. It's down to personal choice. Personally I would rather keep the original system and use Google Maps on the mobile if needs be.
2001 XK8 4.0 Coupe in Quartz
pabr639439
Re: Got the new car
Postby pabr639439 » Thu Nov 04, 2021 7:54 pm
Hi Thank you all for the comments. I am going to try and see if the disc from my 2007 S type will work, I gave the car to my brother , so I have to get the disc back. I really am not to bothered about using the sat nav. just dont want a blank screen.
